Fluent UDF: POSTPROCESSING
i recently started learning udf. My objective is to implement heat flux lines in a square cavity with natural convection. It's supposed to be just like fluent shows us stream lines on "graphics and animations". To do so, i started programing stream lines to be able to compare my results with fluent's results. I'm having basic problems like what DEFINE should i use? And after de code for calculation is done, do i use "return(name)"???? And when its finally compiled, isn't it diferent to calculate some number (like velocity inlet) and show a graphic??? Here's what i've already written: Quote:
am I on the right way? |
I cant even compile this udf :(
