can UDF change the boundary type or turbulence model? |
January 28, 2015, 21:15 |
Haoting Wang
Rep Power: 11 |
I am trying to change the turbulence model I am using depending on the flow speed. For example, I want to use a laminar model when flow speed is 0, and a realizable k-e model when the flow speed is 4 m/s. If possible, how can we do that through UDF? |
January 29, 2015, 07:12 |
Rep Power: 12 |
It is not possible by UDF. It might be possible by an interaction scheme-UDF, but it seems quite complex.
I can't help you, I don't know a lot about scheme. Anyway, what you are trying, if it is possible and you can implement it, I think that I will not be numerically stable, besides it does not make sense to me. If I where you, I would check in your ANSYS Fluent manual the chapter called "How do I choose my turbulent model", for further information. |
January 29, 2015, 09:23 |
#3 | |
Haoting Wang
Rep Power: 11 |
Do you think it would be numerically unstable if I keep changing the models? But if the real condition is like a process have both larminar and turbulent flows at different time, would it be OK if I just use the turbulence model?
January 30, 2015, 03:23 |
Rep Power: 26 |
Doesn't the turbulent model give nearly similar results as the laminar model when you apply it to a laminar situation?
In that case I would just use the turbulent model everywhere. You will use some unnecessary computation time on calculating the (small) turbulence in the laminar zones, but I would not worry about that. |
January 30, 2015, 10:19 |
#5 | |
Haoting Wang
Rep Power: 11 |
The attached figure show the difference. It plots the temperature, the upper one is using a laminar model, the lower one is using a turbulence model. The velocity is 0. All the other boundary conditions are the same. Untitled.jpg |
January 30, 2015, 15:28 |
Rick
Rep Power: 26 |
Did you try the rng k-epsilon?
Google is your friend and the same for the search button! |
January 30, 2015, 17:26 |
Haoting Wang
Rep Power: 11 |
inlet pressure is higher than outlet pressure for fan | sivakumar | OpenFOAM Pre-Processing | 16 | December 30, 2017 14:16 |
Simulation won't show turbulence | pete_87 | OpenFOAM Running, Solving & CFD | 4 | June 25, 2014 11:35 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
