-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   udf problem.. output data comes out to "zero" (http://www.cfd-online.com/Forums/fluent-udf/105874-udf-problem-output-data-comes-out-zero.html)
startup0820 August 11, 2012 07:06
Hi Guys~
I am trying to output to a point w-velocity.
but, All values are output "0".
#include "udf.h"
#define ID1 5 /*ID of the point*/
DEFINE_EXECUTE_AT_END(monkeymagic)
FILE *fp;
Domain *d;
real x[ND_ND];
Thread *t;
cell_t c;
real w=0, time=0;
fp = fopen("velocity.txt","w");
d = Get_Domain(4);
t = Lookup_Thread (d, ID1);
begin_c_loop(c, t)
C_CENTROID(x,c,t);
w= (C_W(c,t));
end_c_loop(c, t)
time=CURRENT_TIME;
fprintf (fp, "%f\n",time);
fprintf (fp, "%f\n",w);
fclose(fp);
If I fix this problem,
Base on this udf source, I will generate 200 points and output velocity.(x, y, z velocity)
Plz anyone help me
What`s the problem of the source code?
gearboy August 12, 2012 23:07
Is this a multiphase problem? Why use "4" in the "Get_Domain"? Usually it should be d = Get_Domain(1) for a single-phase case.
d = Get_Domain(4);
Originally Posted by startup0820 (Post 376570)
Hi Guys~
#include "udf.h"
FILE *fp;
Domain *d;
real x[ND_ND];
Thread *t;
cell_t c;
real w=0, time=0;
d = Get_Domain(4);
begin_c_loop(c, t)
C_CENTROID(x,c,t);
w= (C_W(c,t));
end_c_loop(c, t)
time=CURRENT_TIME;
fclose(fp);
Plz anyone help me
startup0820 August 13, 2012 00:17
Hi, gearboy
Thanks for your answer!
Changed the get domain value 4-> 1
But same results comes out.
What is the problem?
blackmask August 15, 2012 23:09
If I guess correctly, after
t is NULL
The following thread should help you with your task.
http://www.cfd-online.com/Forums/flu...r-xy-plot.html
