FLUENT UDF Simple error.
Old   August 14, 2012, 03:54
Default FLUENT UDF Simple error.
Jong Hwan Park
startup0820 is on a distinguished road
Hello~!
first of all, Thank you for sharing this UDF code.
i tried to compile this source, However, the following error occurred.
..\..\src\test23.c(53) : warning C4133: 'function' : incompatible types - from 'real [3]' to 'CX_Cell_Id *'
..\..\src\test23.c(53) : error C2197: 'SV_locate_point' : too many arguments for call
i don't know why this problem occur.
Please advise if you know I`m using FLUENT 14.0
#include "udf.h"
#include "dpm.h"
DEFINE_ON_DEMAND(locate_point)
CX_Cell_Id *c;
cell_t ct;
Thread *t;
real z[3];
real x[3] = {0.0, 0.0, 0.0};
real pressure;
int N,i;
FILE *output,*points;
Domain *d = Get_Domain(1);
points = fopen("points.txt","r");
output = fopen("results.out","w");
fscanf(points,"%d \n",&N);
/* Read points from the file one by one and write corresponding cell centroid and pressure in 뱑esults.out?*/
for ( i=0;i<N;i++ )
fscanf(points,"%e%e%e\n",&x[0],&x[1],&x[2]);
SV_locate_point(x, z, c);
ct = c->ct.c;
t = c->ct.t;
C_CENTROID(z, ct, t); /*Returns centroid of the cell*/
pressure=C_P(ct,t);
fprintf(output, "Given point %e %e, %e\nFound Cell at %e, %e, %e\nPressure %e\n\n",x[0],x[1],x[2],z[0],z[1],z[2],pressure);
fclose(output);
fclose(points);
startup0820 is offline   Reply With Quote
udf and programming
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
