-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Scheme Problem (http://www.cfd-online.com/Forums/fluent-udf/106228-scheme-problem.html)
ottandr August 22, 2012 10:27
Scheme Problem
Hello!
I have i little problem which should probably easy to solve but i cant find a solution for it.
What the scheme programm should do is the following:
if the scheme variable "udf/marker_geschlossen" is equal to 0 the case and data should be saved in under the specified name.
here is my code that doesnt work:
(if (= (Rpgetvar 'udf/marker_geschlossen) 0)
(file write-case-data "init_trans_test_anfw_4.cas.gz"))
it gives me the following error:
ERROR: eval: unbound variable
ERROR Object: file
if i let the () away in the second line i get the error that i have to many input arguments.
i hope somebody can help me out here as i guess it's a really simply problem that can be solved for sure. Thx in advance!
Yours,
Andi
karthickeyan October 22, 2012 06:24
need to define variable
before using your own variable in scheme function u need to define it in fluent
Originally Posted by ottandr (Post 378194)
Hello!
ERROR Object: file
Yours,
Andi
