Assigning data points as boundary condition using fluent
Old   August 23, 2012, 15:58
Default Assigning data points as boundary condition using fluent
ripong
ripong is on a distinguished road
I have a set of experimental data points, (x,y,v). Here x, y are coordinates in 2-D plane and v is velocity at (x,y).
I would like to give these data points, v, as boundary condition in fluent and see how the flow develops from there.
Do you know how to assign these discrete v values as boundary condition using UDF or any other way?
Thanks,
Boh
ripong is offline   Reply With Quote
Old   August 24, 2012, 15:03
Amir's Avatar
Amir
Amir is on a distinguished road
If these points are located at the boundaries, you can use both UDFs or profiles but if they are in the domain, you can separate the cells which contain them and assign fixed values in BC panel.
Bests,
Amir
Amir is offline   Reply With Quote
Old   August 31, 2012, 05:03
moon
moun139 is on a distinguished road
Yes amir , i think it's easier to use profiles thans UDF's ,
moun139 is offline   Reply With Quote
boundary condition, data points bc, udf and programming
Symmetry boundary condition in Fluent Yesgee FLUENT 5 May 1, 2019 13:31
Use sampled data from previous run as boundary condition for new setup Arnoldinho OpenFOAM Running, Solving & CFD 3 December 6, 2012 13:16
How to define the velocity_inlet boundary condition with existed data for a face? Byron FLUENT 4 September 4, 2010 03:47
set experimental data as boundary condition nalin FLUENT 4 November 16, 2008 09:13
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
