October 24, 2018, 07:34 |
UDF that allowing movement at x direction by Patch Pressure and Temperature
can özbaran
Rep Power: 8 |
Hi
i want to move the projectile in the x direction by implementing patch pressure and temperature at the back of the projectile and using dynamic mesh options.But when i initilaze and then preview the mesh motion i see projectile is not moving.So i guess that it can be caused by three reason.At the dynamic mesh zone section , i set "breech" , "p_out_destruct" boundary conditions as a stationary and set "fluid_mdm_1" fluid zone and "projectile" wall boundary conditions as a rigid body motion.i am using layering mesh method. First possible reason, i cant see any udf create link when i open six dof options at dynamic mesh options menu(can be seen at fourth photo).Is it cause any problem ? i think , it is not.Because i am using "prop[SDOF_ZERO_TRANS_X] = TRUE" in my udf code in order to free the movement in X direction instead of opening "one dof translational movement" at Dynamic Mesh/Options/Six DOF menu. second possible reason is about "patch" section.i identify a region at the back of the projectile and set a pressure and temperature value.Can i make something wrong at this point ? Third reason , is it required any additional region around the projectile base and front wall (making rigid body motion with projectile wall ) i am sharing picture about my model setup and udf i cant upload ansys document into the forum i would be very glad if you help me Last edited by cozt; October 24, 2018 at 09:13. Reason: specific topic |
November 30, 2018, 10:46 |
can özbaran
Rep Power: 8 |
i solved my problem. if anyone has this kind of problem , they can reach me
April 2, 2019, 11:00 |
ozan emre
Hi, I had the same problem.Can you tell me how you solved?
İsim Can olduğu için Türkçe de yazayım. Aynı sorun bende de oluyor bir türlü çözemedim, nasıl çözdüğünü söylermisin. Bir de sakıncası yoksa karşılaştırmak için kendi udf ve mesh dosyalarını gönderebilirmisin. ozan.emre.1993@gmail.com Teşekkürler, iyi çalışmalar. |
June 11, 2019, 09:32 |
Mohsen
Hi.How did you solve it?
How to set up an overset mesh ? (Moving square inside a rectangular box) | jordan.c | STAR-CCM+ | 5 | September 6, 2019 08:53 |
How to simulate a sphere moving inside a fluid region | jsb12136 | STAR-CCM+ | 3 | April 18, 2015 11:59 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 05:32 |
