Variable definition in UDF
Old   October 1, 2012, 17:17
Default Variable definition in UDF
Syavash Asgari
syavash is on a distinguished road
Hi friends,
I am implementing a Define_execute_at_end macro in a transient simulation.
I have a variable, named "j" which has an certain initial value at first time step. But inside the macro, it's value changes and this variable is updated.
Now for second time step I need to use the updated value of "j" and the problem is here. If I define "j" as a static variable and assign an initial value to it inside the macro, how is it possible to access the updated value of "j" for the second time step? As I know the variables are all reset at each new time step unless they're already defined as "static", but how to skip that initial value for the second time step?
I appreciate any kind of help.
tnx.
syavash is offline   Reply With Quote
global variable in udf mohsen zendehbad FLUENT 2 November 22, 2009 05:30
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
Do I need to use UDF to get time-averaged variable? ivanbuz Fluent UDF and Scheme Programming 0 August 11, 2009 14:26
Variable for AVERAGE VELOCITY, Pressure etc. in UDF? aam Fluent UDF and Scheme Programming 0 May 15, 2009 05:21
