October 1, 2012, 17:17 |
Variable definition in UDF
Syavash Asgari
Rep Power: 18 |
Hi friends,
I am implementing a Define_execute_at_end macro in a transient simulation. I have a variable, named "j" which has an certain initial value at first time step. But inside the macro, it's value changes and this variable is updated. Now for second time step I need to use the updated value of "j" and the problem is here. If I define "j" as a static variable and assign an initial value to it inside the macro, how is it possible to access the updated value of "j" for the second time step? As I know the variables are all reset at each new time step unless they're already defined as "static", but how to skip that initial value for the second time step? I appreciate any kind of help. tnx. |
global variable in udf | mohsen zendehbad | FLUENT | 2 | November 22, 2009 05:30 |
UDF extern variable - mean time moment coefficient | enry | Fluent UDF and Scheme Programming | 0 | November 14, 2009 06:56 |
UDF extern variable - mean time moment coefficient | enry | Fluent UDF and Scheme Programming | 0 | November 14, 2009 06:51 |
Do I need to use UDF to get time-averaged variable? | ivanbuz | Fluent UDF and Scheme Programming | 0 | August 11, 2009 14:26 |
Variable for AVERAGE VELOCITY, Pressure etc. in UDF? | aam | Fluent UDF and Scheme Programming | 0 | May 15, 2009 05:21 |
