Assign limit in udf for Temperaure and Pressure
Old   October 15, 2012, 10:45
Default Assign limit in udf for Temperaure and Pressure
Yogini Patel
Yogini is on a distinguished road
I am writing my udf in fluent for material properties. Where I have to assign certain limit for both temperature and pressure in the beginning of the udf.
Also this bounded value, I want to use it in other properties in the same udf.
Can any one give me some ideas how I can define limit in udf ?
Thank you
BR,
-Yogini
Yogini is offline   Reply With Quote
Old   October 16, 2012, 21:25
Syavash Asgari
syavash is on a distinguished road
Thank you
BR,
-Yogini
You can establish a loop over either faces or cells and check the parameters you wish. If their values would have exceeded maximum range, you can be informed by an if-clause, for example:
if (C_P(c,t) > 1e+10)
Error("pressure has exceeded maximum range");
Above command lines will stop UDF procedure.
Goodluck
syavash is offline   Reply With Quote
Old   October 17, 2012, 10:11
Yogini Patel
Thank you for your reply.
In my case I am using wet-steam udf for calculating thermodynamical properties (like, P, T, Cp, Cv, rho, etc). All are the functions of T and Rho in polynomial form.
In my case, the calculated values in fluent increased too much. That's why I want to set a certain limit for Temp. and rho. Like one example,
P = f(T,rho),
if T > 360 K then T = 360 K
else T = T
Same for rho also.
I want to put this 'if-else' clause in my udf, can you guide me how to write it?
-Yogini
Old   October 17, 2012, 11:44
Syavash Asgari
P = f(T,rho),
else T = T
Same for rho also.
-Yogini
Tell us more about your UDF. What kind of Macro is used?
calculation average pressure in a plane with UDF Vitalij FLUENT 1 April 10, 2007 03:39
Setting pressure value for specific cells, UDF Amir FLUENT 2 September 1, 2005 18:59
UDF CALL FOR PRESSURE D Harvey FLUENT 2 June 3, 2004 21:46
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
