-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Deforming boundary- smoothing error (http://www.cfd-online.com/Forums/fluent-udf/108211-deforming-boundary-smoothing-error.html)
michalRS October 17, 2012 06:22
Hello All
I am currently trying to model flow through a tunnel, where a small part of the boundary deforms in time. the deformation is basically a small, solid "bubble" that expands into the flow and collapses back on the wall periodically(prescribed motion, not due to fluid interaction).
I wrote a udf inspired by "define-grid-motion" in the Fluent manual, and this works wonderfuly for one cycle, but in the middle of the second cycle the smoothing of the mesh fails, and negative cell volumes are created. :confused:
I tried changing the time step, and the diffusion parameter (under smoothing parameters of the dynamic mesh) but these hardly affected the problem.
1- can anyone suggest why this happens on the second cycle, and what I can do to prevent this?
2- if I save all the case files during the first cycle, can I write a udf that loads all the meshes periodically to create the same motion without having to go through the smoothing process each time?
thank you for any suggestions or comments
