Negative volumes when using UDF in VIV in a cylinder |
October 16, 2011, 01:42 |
w-coche
Hello all,
I am trying to solve the VIV case in a cylinder when Re=100 in Fluent 6.3. I have the solution when the cylinder is at rest, and my results are accurate. However, my problems appear when I try to use an UDF. When it is iterating, it stops because negative volumes appear. I do not know what I am doing wrong. My udf that I am using is one that I found on Internet: #include "udf.h" static real v_prev = 0.0; DEFINE_CG_MOTION(osc,dt,vel,omega,time,dtime) { Thread *t; Domain *d = Get_Domain(1); real x_cg[3], force[3], moment[3]; real accl, dv; real mass = 0.2; real wn = 12.0; real k= mass * wn*wn; real c = 2*mass*wn*0.00; int i; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); t = DT_THREAD(dt); for(i=0;i<3;i++) x_cg[i]=DT_CG(dt)[i]; Compute_Force_And_Moment(d, t, x_cg, force, moment, TRUE); force[1] += -k*x_cg[1] - c*vel[1]; accl = force[1]/mass; dv = accl*dtime; v_prev+=dv; vel[1] = v_prev; printf("Computed force: %g \n", force[1]); printf("Velocity: %g\n", vel[1]); } DEFINE_CG_MOTION(osc_inert,dt,vel,omega,time,dtime ) { vel[0] = 0.0; vel[1] = v_prev; } My parameters are based on smoothing and remeshing, and I am hooking osc to my cylinder. Here is attached my mesh. Please I need your help because I do not know if I need to change the mesh or I need to change some of the parameters. Thanks, Willy |
May 31, 2012, 12:34 |
zhang guoqing
Rep Power: 14 |
Hi:
Have u solve your problem regarding the negative grid? Could u tell me? Tks. |
June 1, 2012, 04:06 |
Jessica Simberg
Rep Power: 14 |
You need to define another fluid zone which surrounds your body and moves with it...
Can you send me your case & mesh (jessica.simberg@gmail.com)? |
June 4, 2012, 06:47 |
Rep Power: 14 |
W-COCHE...have you fixed your problem?
October 19, 2012, 07:25 |
Hi
Is the above udf correct? how and where you are calculating the pressure and viscous forces? I guess there should be a loop for calculating pressure and viscous forces acting on the cylinder. If someone have an answer to this please reply |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
trailing edge negative volumes | Nick R | ANSYS Meshing & Geometry | 2 | February 2, 2011 02:05 |
Mesh orientation and negative volumes | Nick R | CFX | 3 | January 10, 2011 16:34 |
body has to move in positive and negative x-direction (UDF?) | bobo | FLUENT | 0 | July 2, 2009 06:41 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
