call data generated by Fluent
Old   November 8, 2012, 18:36
Default call data generated by Fluent
guoji xu
gxu2 is on a distinguished road
I want to call data, like "drag coefficient" generated by Fluent every time step by employing UDF, and make some calculations then some data generated again, and newly generated "drag coefficient" is called again by UDF, and so on so forth.
so how to call the data? How to write the UDF?
Further, the data format type saved is "file", not ".txt", then any good idea to solve this problem.
Thank you in advance!
Best regards!
Gxu2
gxu2 is offline   Reply With Quote
Old   November 12, 2012, 03:20
SSL
msaeedsadeghi is on a distinguished road
You can find it in "dpm.h" header file.
msaeedsadeghi is offline   Reply With Quote
Old   November 19, 2012, 10:31
guoji xu
thank you very much, Saeed Sadeghi
I will look up this document.
Best regards
gxu2
Plotting Fluent data with MATLAB jgrisham FLUENT 0 March 25, 2012 20:28
post processing using fluent data Ramesh.K FLUENT 3 October 29, 2008 11:20
Parallel UDF data passing causes Fluent to hang Tom FLUENT 2 June 9, 2006 13:17
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
data output from batch fluent run Wang FLUENT 4 March 11, 2005 11:01
