Pressure modification using flux at outlet boundary (udf) |
December 27, 2012, 03:30 |
Jihoon Kweon
I am a new comer to fluent and udf world. I REALLY need your help. I have been trying to modify the pressure at the circular pipe exit using the mass flux. From several trials, I found that the source of error was 'F_FLUX(f,t)' in 12th line. F_FLUX(f,t) is needed to be pre-defined? I want the pressure profile is updated at every time step. Thank you in advance.
1 #include "udf.h" 2 DEFINE_PROFILE(pressure_profile, t, i) 3 { 4 real pressure; 5 real flt = 0.; 6 real density = 1060.; 7 real pref = 13332.2368; 8 real flref = 6.4*10e-6; 9 face_t f; 10 begin_f_loop(f,t) 11 { 12 flt=F_FLUX(f,t)/density; 13 pressure = pref*flt/flref; 14 F_PROFILE(f, t, i) = pressure; 15 } 16 end_f_loop(f,t) 17 } |
January 1, 2013, 09:47 |
SSL
Rep Power: 14 |
The UDF is correct, but you can not modify outlet pressure.
flux, pressure, profile, udf |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
How can I implement time varying pressure boundary condtion through UDF | nacaairfoil | FLUENT | 0 | October 11, 2011 13:03 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Pressure Boundary Problems | Chris | Siemens | 2 | June 21, 2005 08:20 |
