Wall surface reaction, definition issue
Old   January 16, 2013, 08:23
Default Wall surface reaction, definition issue
Gerry Boyce
GBNB is on a distinguished road
Hi there,
I was wondering if someone could help me with a problem I am having regarding defining a wall surface reaction UDF. I am trying to model platelet transport in blood and platelet interaction with blood vessel walls. I have defined two platelet species (gas species), Resting Platelets (RP) and Activated Platelets (AP). I have a source term for each of the species and I am trying to define a reactive wall flux term that accounts for platelet deposition on the vessel walls.
In the DEFINE_SR_REACTION macro, I have defined 2 wall surface reactions - reaction-1 for RP flux to the wall and reaction-2 for AP flux to the wall
In the UDF I am returning a reaction rate value in the pointer *rr (kmole/m^2-s)
In the Edit Reactions dialogue box (Problem Setup -> Materials -> mixture-template -> Reactions-Edit) I have set the following parameters:
reaction-1:
Reactant Specie = RP, Stoic. Coeff. = 1, Rate Exponent = 1
Product Specie = RP, Stoic Coeff. = 1, Rate Exponent = 0
reaction-2:
Reactant Specie = AP, Stoic Coeff. = 1, Rate Exponent = 1
Product Specie = AP, Stoic Coeff. = 1, Rate Exponent = 0
When I run the model I see no flux of AP or RP to the wall surface and I'm not quite sure what I'm doing wrong. Any help would be greatly appreciated! Thanks!
GBNB is offline   Reply With Quote
Old   February 22, 2013, 17:59
Tim Maguire
timjm is on a distinguished road
Gerry:
Did you end up finding a solution to this problem?
timjm is offline   Reply With Quote
Old   February 23, 2013, 02:09
SSL
msaeedsadeghi is on a distinguished road
I have modeled so many combustion problems. What is the problem. He may have not written the UDF correct.
msaeedsadeghi is offline   Reply With Quote
surface reaction, porous media Ali FLUENT 2 March 31, 2016 17:26
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Wall Surface Reaction!!!! ansonkuo FLUENT 0 December 24, 2007 02:15
wall surface reaction Razvan FLUENT 0 April 5, 2005 05:10
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
