Error while running UDF - Fluent
Old   March 17, 2011, 04:58
Default Error while running UDF - Fluent
r
roca is on a distinguished road
Hello!
I get the following error message while I run the simulation with an UDF
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
I have no problems in compiling and interpreting this UDF. I have found that the problem is linked to following part of the code below.
Thread *tc = THREAD_SUPER_THREAD(thread); /*obtain mixture thread */
Thread **pt = THREAD_SUB_THREADS(tc); /* pointer to sub_threads */
Thread *tp = pt[P_PHASE]; /* primary phase thread */
solute_mass_frac=C_YI(cell,tp,0);
When I run the simulation with the UDF and I specify solute_mass_frac=0.5 (for example 0.5) the simulation runs without errors. So, this has to be linked to C_YI(cell,tp,0). Or probably to the way ''tp'' is set.
Does anybody could tell me what I am doing wrong?
thank you in advance
roca is offline   Reply With Quote
Old   March 6, 2013, 05:33
Andrej POHAR
apohar is on a distinguished road
I have exactly the same problem, I narrowed it down to solute_mass_frac = C_YI(cell,tp,0);
Did you manage to solve it? Thanks in advance.
apohar is offline   Reply With Quote
Old   March 7, 2013, 02:30
Andrej POHAR
I found the answer in the manual, C_YI isn't defined so you have to use Pdf_Yi(cell,tp,0)
c_yi, error, mass fraction, udf
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Compiling UDF in Fluent 12 jsm FLUENT 1 July 22, 2009 07:40
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
need some basic help with fluent udf aarti sekaran FLUENT 8 February 12, 2008 00:57
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
