Direct condensation of steam to subcooled water spray
Like Tree1Likes
  • 1 Post By pakk
Old   November 18, 2021, 10:57
Exclamation Direct condensation of steam to subcooled water spray
mohammad reza
m.r.soufivand is on a distinguished road
As in the article " https://doi.org/10.1016/j.cep.2019.04.015 ", I want to simulate direct condensation of steam to subcooled water spray.
The results are good when I simulate only hydrodynamics, but when I compile the UDF to mass transfer and add source terms, In the first few iterations, it diverges and gives the following error:
"WARNING: Invalid cp (0.000000e+00 J/kgK) for water-vapor at temperature nan K
Error at host: floating point exception
Error: floating point exception
Error Object: #f"
I have attached the UDF to this post. I would be grateful if you could help me.
Last edited by m.r.soufivand; November 18, 2021 at 11:00. Reason: I forgot to upload the attachment
m.r.soufivand is offline   Reply With Quote
Old   November 19, 2021, 00:18
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
your code
#include "udf.h"
#include "math.h"
#include "sg.h"
#include "sg_mphase.h"
#include "flow.h"
#include "mem.h"
#include "metric.h"
#define R 8.314
#define pi 3.14159
#define T_SAT 373.15
#define h_lv 2455.1345e3
#define M 18.0
#define Beta 0.6666
#define a 23.224
#define b 3841.22
#define cc  -45.0
DEFINE_ADJUST(store_gradient, domain)
Thread *t;
Thread **pt;
cell_t c;
int phase_domain_index = 0.;
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,phase_domain_index);
Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL);
Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL);
Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate);
mp_thread_loop_c (t,domain,pt)
if (FLUID_THREAD_P(t))
Thread *ppt = pt[phase_domain_index];
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_VOF_G(c,ppt)[0];
C_UDMI(c,t,1) = C_VOF_G(c,ppt)[1];
C_UDMI(c,t,2) = NV_MAG(C_VOF_G(c,ppt));
end_c_loop (c,t)
Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NULL);
DEFINE_SOURCE(vap_src, cell, pri_th, dS, eqn)
Thread *mix_th, *sec_th;
real m_dot_v,T_v,T_l,P_v,P_sat;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th,1);
T_v=C_T(cell,pri_th);
P_v=C_P(cell,pri_th);
T_l=C_T(cell,sec_th);
P_sat=exp(a-(b/(T_l+cc)));
if(C_T(cell,mix_th)>=T_SAT)
m_dot_v = 0.0;
dS[eqn] = 0.0;
if(C_T(cell,mix_th)<=T_SAT)
m_dot_v =C_VOF(cell,sec_th)*(2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
C_UDMI(cell,mix_th,3) =m_dot_v;
dS[eqn] = 0.0;
return m_dot_v ;
DEFINE_SOURCE(liq_src,cell,sec_th,dS,eqn)
Thread * mix_th, *pri_th;
real m_dot_l,T_v,T_l,P_v,P_sat;
mix_th=THREAD_SUPER_THREAD(sec_th);
pri_th=THREAD_SUB_THREAD(mix_th,0);
T_v = C_T(cell,pri_th);
P_v = C_P(cell,pri_th);
T_l = C_T(cell,sec_th);
m_dot_l = 0.0;
dS[eqn] = 0.0;
m_dot_l = C_VOF(cell,sec_th)*(2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
C_UDMI(cell,mix_th,4) =m_dot_l;
dS[eqn] =(2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
return m_dot_l;
DEFINE_SOURCE(enrg_src,cell,mix_th,dS,eqn)
Thread *pri_th, *sec_th;
real m_dot,T_v,T_l,P_v,P_sat;
pri_th = THREAD_SUB_THREAD(mix_th,0);
m_dot =0.0;
dS[eqn] =0.0;
m_dot=C_VOF(cell,sec_th)*(2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
C_UDMI(cell,mix_th,5) =h_lv*m_dot;
dS[eqn]= 0.0;
return h_lv*m_dot; }
in this code I would change only 1 thing, which probably will not affect
was #define h_lv 2455.1345e3
to be #define h_lv 2.4551345e6
from your error I may assume you have problem with temperature convergence.
you may decrease time step
check your mesh
check boundary conditions
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 19, 2021, 05:58
pakk will become famous soon enough
I tried to refactor your code, because you repeated your equations a few times:
#include "udf.h"
#include "math.h"
#include "sg.h"
#include "flow.h"
#include "mem.h"
#include "metric.h"
#define R 8.314
#define pi 3.14159
#define M 18.0
#define Beta 0.6666
#define a 23.224
#define b 3841.22
#define cc  -45.0
 Thread *t;
 Thread **pt;
 cell_t c;
  begin_c_loop (c,t)
 end_c_loop (c,t)
real ds(Thread* pri_th, Thread* sec_th, cell_t cell) {
 real T_v, T_l, P_v, P_sat, dS;
 if(C_T(cell,mix_th)>=T_SAT) {
  dS = 0;
 } else {
  P_sat=exp(a-(b/(T_l+cc)));dS;
  dS = (2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
 return dS;
real mdot(Thread* pri_th, Thread* sec_th, cell_t cell) {
 real T_v, T_l, P_v, P_sat, m_dot;
  m_dot = 0;
 } else {
  m_dot = C_VOF(cell,sec_th)*(2.0*Beta/(2.0-Beta))*C_UDMI(cell,mix_th,2)*sqrt(M/(2*pi*R))*((P_v/sqrt(T_v))-(P_sat/sqrt(T_l)));
 return m_dot;
 Thread* mix_th = THREAD_SUPER_THREAD(pri_th);
 Thread* sec_th = THREAD_SUB_THREAD(mix_th,1);
 real m_dot_v=mdot(pri_th, sec_th, cell);
 C_UDMI(cell,mix_th,3) = m_dot_v;
 dS[eqn] = 0.0;
 return m_dot_v ;
 Thread* mix_th=THREAD_SUPER_THREAD(sec_th);
 Thread* pri_th=THREAD_SUB_THREAD(mix_th,0);
 real m_dot_l=mdot(pri_th, sec_th, cell);
 C_UDMI(cell,mix_th,4) = m_dot_l;
 dS[eqn] = ds(pri_th, sec_th, cell);
 return m_dot_l;
 Thread* pri_th = THREAD_SUB_THREAD(mix_th,0);
 real m_dot=mdot(pri_th, sec_th, cell);
 C_UDMI(cell,mix_th,5) = h_lv*m_dot;
 dS[eqn]= 0.0;
 return h_lv*m_dot;
This should be functionally the same (but I did not test it). What is now more apparent is that your two mass sources have the same sign, where I would expect them to differ in sign (whatever leaves the liquid zone should enter the vapor zone and vice versa).
I also noticed that only one of your sources specifies dS (as non-zero); the code above is (relatively) easy to change if you want to improve that.
m.r.soufivand likes this.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   November 19, 2021, 09:15
mohammad reza
Thanks so much for your response and help. I try to use your code but gives the error is that mix_th is not defined.
Old   November 20, 2021, 02:47
I see, the definitions for ds and mdot should also have this:
condensation, divergence issue, mass transfer, udf
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 04:03
VOF Steam condensation Andrea159357 FLUENT 4 March 19, 2019 14:20
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 14:27
Steam Mixture material for Wall condensation coolcrasher CFX 2 October 19, 2015 09:23
How to solve condensation case with HBM model (NO WATER)? kiwishall CFX 0 December 23, 2013 20:47
