problem in udf
Like Tree1Likes
  • 1 Post By A CFD free user
Old   April 13, 2013, 15:47
Default problem in udf
pratik
pratkb is on a distinguished road
Can anyone please help me in using udf in ansys?basically i have to give a parabolic velocity inlet in 2-d geometry using udf.
will be waiting..
pratkb is offline   Reply With Quote
Old   April 13, 2013, 16:08
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi Pratik
You only need to define your own code by using DEFINE_PROFILE macro and then interpret or compile it. If you only have this simple macro, I suggest you that use interpret option. Afterwards, you should hook it up through Boundary condition/Inlet/ Velocity (x, y direction). Here's the structure of a DEFINE_PROFILE UDF:
DEFINE_PROFILE(your desired name for UDF, t, i)
cell_t c;
real x[ND_ND];
define others parameters
real ...
real ...
real ...
begin_c_loop(c,t)
C_CENTROID(x,c,t);
F_PROFILE(c,t,i)=......
end_c_loop(c,t)
Hope it help
Good luck
pratkb likes this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 13, 2013, 16:55
Default Udf
pratik
Thank you very much.I am also following some of the pdf on udf in net.Being very new to this software and eager to learn it,if you please help me about the steps and processings to carry out my job or attach any file,I will be very grateful to you..
The parabolic inlet eqn is 2(1-r/R)^2...
Old   April 13, 2013, 23:49
shuai_manlou's Avatar
CAO Liushuai
shuai_manlou is on a distinguished road
You can find the similar example in FLUENT UDF HELP, make some corrections and you can use it in your own case.
shuai_manlou is offline   Reply With Quote
udf
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
