trying to adapt the tutorial: Using a UDF Flexible Oscillating membrane
Like Tree2Likes
  • 1 Post By vasava
  • 1 Post By hellovers60
Old   April 15, 2013, 13:38
Default trying to adapt the tutorial: Using a UDF Flexible Oscillating membrane
musab
bluAero is on a distinguished road
I read that tutorial name : Using a UDF to Control the Dynamic Mesh of a
Flexible Oscillating Membrane ...
and i used it in fluent .. also i used the attachment c file ( that name is : butterfly-flex.c )
the moving type of membrane is ( moving arc motion ) .
but i note that the memberane length from this coordinates (-0.083552375 , -0.1 ) To (0.083552375 , -0.1 ) , which mean its length is 0.16710475 , and the center of arc is ( 0 , -0.1 ) ..
i need that :-
1- i need to use this ( arc motion ) for another membrane that have another length ( in example for 0.5 ) , what i shall to do in the C file ??
2- i need to put the center of arc in another point in x direction ( in example : ( 3 , -0.1 ) , how i can do that ??
3- what is the mean of any one of these ?
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[2] = omega;
bluAero is offline   Reply With Quote
Old   April 15, 2013, 17:14
musab
can any one help me ??
Old   April 16, 2013, 03:44
Paritosh Vasava
vasava will become famous soon enough
You need to change the 'moving_arc' part of the UDF based on the dimension and motion of your boundaries. If you have the original UDF (and the PDF file) the comments in the UDF are very useful.
You must do that in fluent (dynamic mesh settings). However you must modify the UDF in accordance to how you anticipate the motion.
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
There are the linear and angular velocities of the center of gravity.
bluAero likes this.
vasava is offline   Reply With Quote
Old   August 14, 2013, 01:55
Ankit Gohel
hellovers60 is on a distinguished road
i am also facing the same problem.
I have to oscillate the cylinder to 180 degree.
i have to write the udf for the same.
but when i enter the udf it takes the inlet velocity insted of rotational motion....
hellovers60 is offline   Reply With Quote
Old   August 15, 2013, 04:47
Paritosh Vasava
@Ankit: Can you post your UDF here? we can have a look.
Old   August 23, 2013, 00:55
Ankit Gohel
#include"udf.h"
#define ZONE_ID 3
#include<math.h>
#define dynamesh_tools.h
#define p 22/7
#define a 2*p /* when a=2*p*f, and take f=1*/
static real omega[2]_prev = 0.0;
DEFINE_CG_MOTION(cylinder, dt, velocity, omega, time, dtime)
Thread*t;
face_t f;
velocity[0]=0.0;
velocity[1]=0.0;
velocity[2]=0.0;
omega[0]=0.0;
omega[1]=0.0;
if (!Data_Valid_P())
return;
t=DT_OMEGA_CG(t);
domega[2] = a*sin(2*p*f*dtime);
omega[2]_prev += omega[2];
Message ("time = %f, omega[2] = %f\n", time, omega[2]_prev);
omega[2]=a*sin(2*p*f*time);
but in that omega[2] equation there is forcing frequency...
still i dont know... because when i go through the paper they always talk about ration of f/f0. where f0 is vortex shadding frequency of steady cylinder.
If there is some prob than pls help me
Thanks
zhaomu67 likes this.
Old   August 23, 2013, 03:13
Paritosh Vasava
You have so many problems with your UDF.
1. The use of 'f'.
2. The use of 't'
3. The use of 'omega[2]_prev'.
4. I think that you can avoid using 'a' and 't=DT_OMEGA_CG(t);'.
And so on.........
Here is the corrected UDF.
#include "udf.h"
#include "dynamesh_tools.h"
#define p1 22/7
#define f1 1.0
DEFINE_CG_MOTION(cylinder, dt, cg_vel, cg_omega, time, dtime)
Thread*t;
face_t f;
real omega_prev;
omega_prev = 0.0;
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
return;
/* t = DT_OMEGA_CG(dt); */
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[2] = (2*p1)*sin(2*p1*f1*dtime);
omega_prev = omega_prev + cg_omega[2];
Message ("time = %f, omega[2] = %f\n", time, omega_prev);
Lets see if that works for you..
Old   August 28, 2013, 10:48
Ankit Gohel
Sir, Now its create problem in compile.
Its give an error report
nmake is not recognized as an internal or external command
Open_udf_library: the system cant find the file specified.
Old   August 30, 2013, 23:14
Ankit Gohel
Finally, the udf is successfully executed. Thnaks... But after some iteration it gives an error " divergence detected in AMG solver: Pressure correction"
Old   December 7, 2015, 17:12
Default divergence detected
bia
nabaouia
bia is on a distinguished road
I 've faced the same problem when simulating a dynamic mesh of a moving membrane after some iterations it diverge ''divergence detected in AMG solver x momentum .'
I tried with all the velocity and pressure schemes , different time steps , adaptative time step, implicit update... but always thye same divergence just the error message change from'' x momentum to y momentum ''
stuck there for months just wanna be cool to not get crazy .
bia is offline   Reply With Quote
Old   June 26, 2018, 03:55
Saman95 is on a distinguished road
hello
please say how i can find case and data file?
Saman95 is offline   Reply With Quote
Old   June 26, 2018, 03:56
i need that :-
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
hello
Old   June 26, 2018, 06:04
Default case file
  #13
I search on web but I can't find the case file
please send me address link or send case file to my Email.
Samanabasian95@gmail.com
UDF for object oscillating in direction of flow tsaget Fluent UDF and Scheme Programming 11 September 15, 2015 15:07
tutorial for solving oscillating cylinder problem CH FLUENT 8 April 2, 2014 10:56
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
UDF tutorial 18 jan Main CFD Forum 0 October 16, 2006 04:05
UDF in MDM Tutorial mAx FLUENT 0 November 28, 2005 07:34
