October 27, 2020, 20:45 |
How to create string-name with variable
Hi all,
I have the following problem. I want to write the interpolate-data (.ip) after every timestep. So I wanted to do this by using excecute-command and calling a journal file. However fluent automatically overwrites the old .ip file. So is there any possibility to include for example the simulation time in the string of the name? I want something like this: (define MYFILENAME (rpgetvar 'flow-time)) (ti-menu-load-string "file/interpolate/write-data MYFILENAME yes yes ") Or is this simply not possible? Maybe you have a better solution. I am not an expert in scheme... totally the opposite unfortunately. |
October 29, 2020, 07:06 |
Alexander
Rep Power: 34 |
you may try something like this:
(ti-menu-load-string (format #f "file/interpolate/write-data my_case_~a yes yes \n" (rpgetvar 'flow-time)))
best regards ****************************** press LIKE if this message was helpful |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 21:49 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
