UDF for inflow
Old   April 26, 2013, 15:14
Default UDF for inflow
OMJT is on a distinguished road
Hi everyone,
I am having an issue getting fluent to work with a ramped inflow condition. I have a UDF file for a simple ramp written and I have a journal file written but I get back an error everytime saying:
"Primitive Error at Node 1: interpolate_profile_field: thread 24: profile \"\" does not exist."
It is running in 2D and uses parrallel processing. Here are the files:
ramped_inflow.c
#include "udf.h"
DEFINE_PROFILE(inlet_velocity, thread, position)
    real ramp = 0.0;
    real t_ramp = 0.0;
    real u_target = 0.0;
    real u_in = 0.0;
    t_ramp = RP_Get_Real("t_ramp");
    u_target = RP_Get_Real("u_target");
    #if !RP_HOST /* (serial or compute process, i.e. not host process) */
        real x[ND_ND];
        face_t f;
        if (CURRENT_TIME <= t_ramp && t_ramp > 0.0)
                ramp = CURRENT_TIME/t_ramp;
            u_in = ramp * u_target;
                    if (u_in == 0.0)
                        u_in = 0.02;    /* cannot initialise flow if u=0 m/s */
        else
            ramp = 1.0;
        begin_f_loop(f,thread)
            F_CENTROID(x, f, thread);
            F_PROFILE(f, thread, position) = u_in;
        end_f_loop(f,thread)
    #endif
Here is the journal file:
; READ MESH
/file rc "F2R2T1a.cas"
; COMPILE UDFS
/define ud cf c "libudf" y "ramped_inflow.c" , ,
; set target velocity = 2.0 m/s
(rp-var-define 'u_target 1.0 'real #f)
; set ramp time = 10 s
(rp-var-define 't_ramp 10 'real #f)
/define ud cf l "libudf"
; BOUNDARY CONDITIONS
/define bc vi inlet y y y y "udf" "inlet_velocity::libudf" n 0 y n n 0 y n 1 n 1
; INITIALISE
/solve initialize compute-defaults vi inlet y
/solve initialize initialize-flow
; SOLVE
/solve dual-time-iterate 30000 40
; SAVE CASE AND DATA FILES
/file write-case-data F2R2T1ax.cas y
/file write-case-data F2R2T1ax.dat y
/exit yes
All help will be much appreciated!
Thanks,
Matt
OMJT is offline   Reply With Quote
Old   April 29, 2013, 22:34
blackmask will become famous soon enough
I think that you should attach the running log of fluent while reading the journal file.
I barely know UDF so I am a bit confused when reading your source code. Maybe you could help me with the following two questions?
1. Judge from the macro you used (!RP_HOST), the RP_Get... should be executed by HOST only. So why broadcasting those values to non-host processes is unnecessary?
2. Two floating numbers could be equal (r1 == r2 could be true) but people seldom do this. The more common practice I saw is ( fabs(r1-r2) < some_eps ). So do you have any particular reason for this line of code?
if (u_in == 0.0)
blackmask is offline   Reply With Quote
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
