[solidification/melting] udf to init Temperature
Like Tree1Likes
  • 1 Post By ghost82
Old   November 28, 2012, 01:53
Default [solidification/melting] udf to init Temperature
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I'm trying to solve a solidification-melting problem and I have to initialize temperature, function of x coordinate: I used the following udf, which compiles/interprets fine:
#include "udf.h"
DEFINE_INIT(my_init_func,d)
  cell_t c;
  Thread *t;
  real xc[ND_ND];
  /* loop over all cell threads in the domain  */
  thread_loop_c(t,d)
      /* loop over all cells  */
      begin_c_loop_all(c,t)
          C_CENTROID(xc,c,t);
            if (xc[0] <= 0.015)
                C_T(c,t) = 346.15;
            else if (xc[0] <= 0.01575 && xc[0] > 0.015)
                C_T(c,t) = -2208.*xc[0]+351.171;
            else if (xc[0] <= 0.01625 && xc[0] > 0.01575)
                C_T(c,t) = -414.*xc[0]+322.9155;
            else if (xc[0] <= 0.01675 && xc[0] > 0.01625)
                C_T(c,t) = -66.*xc[0]+317.2605;
            else if (xc[0] <= 0.01725 && xc[0] > 0.01675)
                C_T(c,t) = -8.*xc[0]+316.289;
            else if (xc[0] <= 0.01775 && xc[0] > 0.01725)
                C_T(c,t) = -2.*xc[0]+316.1855;
            else
                C_T(c,t) = 316.15;
      end_c_loop_all(c,t)
Solidus temperature for my problem is 316.15 K, liquidus temperature 327.15 K;
However, after initializing, temperature contour plot looks fine, but when I plot liquid fraction my domain is 100% liquid....
Do I have to patch also the liquid fraction in my udf?If yes, how?
Daniele
thermal energy likes this.
ghost82 is offline   Reply With Quote
Old   November 28, 2012, 03:15
ghost82's Avatar
Rick
I initialized also the liquid fraction thanks to C_LIQF(c,t) to 0; my problem was that I initialized all my domain, whch is composed by solid and fluid, but, as the fluent guide says, C_LIQF(c,t) is available only for fluid zones, so I received an access violation..now all is ok (I think).
..but I didn't know that I had to initialize also the liquid fraction, I thought that fluent would compute it automatically.
Daniele
Old   June 19, 2013, 02:31
Yash Ganatra
yashganatra is on a distinguished road
I am also working on the same problem. Were you able to solve this problem? I know it's late, you should also update enthalpy right to get the updated liquid fraction? Did you use the inbuilt solidification module?
yashganatra is offline   Reply With Quote
UDF slip and temperature jump from IFRT abir Fluent UDF and Scheme Programming 1 July 30, 2012 05:44
UDF temperature profile NeoGamaes Fluent UDF and Scheme Programming 5 January 16, 2012 03:10
Parallel INIT UDF trouble mil3st3g Fluent UDF and Scheme Programming 2 January 6, 2011 14:07
UDF of linear distribution of temperature in a 2D tank arailos Fluent UDF and Scheme Programming 1 August 19, 2010 14:14
UDF or any approach for Bulk Temperature calculation vemps FLUENT 0 May 1, 2009 01:09
