June 3, 2013, 13:27 |
UDF value to large for defined data type
anna
Hi everyone,
I'm new to Fleunt and this is my first time interpreting a UDF. When using the Interpreted UDFs dialogue in Fluent version 14.5 I get the following error: cpp -I "/usr/css/apps/ansys_inc/v145/fluent/Fleunt14.5.0/src" ... : Value too large for defined data type cpp: netudf.c: Value too large for defined data type Error: "netudf.c": line 1: syntax error. Anyone know what this means? My UDF, netudf.c, is below: # include "udf.h" DEFINE_PROFILE(ICA,thread,position) { face_t f; real t = CURRENT_TIME; begin_f_loop(f,thread) { F_PROFILE(f,thread,position)=(1/11.716310)*(4.600000/3.8909)*(3.8909-(0.0725*cos(2*3.14*(0.9-t)/0.9))-(0.1920*cos(2*2*3.14*(0.9-t)/0.9))-(0.4004*cos(2*3*3.14*(0.9-t)/0.9))-(0.2157*cos(2*4*3.14*(0.9-t)/0.9))-(0.2692*cos(2*5*3.14*(0.9-t)/0.9))-(0.0699*cos(2*6*3.14*(0.9-t)/0.9))+(0.0607*cos(2*7*3.14*(0.9-t)/0.9))+(0.0140*cos(2*8*3.14*(0.9-t)/0.9))+(0.0409*cos(2*9*3.14*(0.9-t)/0.9))-(0.0015*cos(2*10*3.14*(0.9-t)/0.9))-(0.0193*cos(2*11*3.14*(0.9-t)/0.9))-(0.0312*cos(2*12*3.14*(0.9-t)/0.9))-(0.0571*cos(2*13*3.14*(0.9-t)/0.9))-(0.0205*cos(2*14*3.14*(0.9-t)/0.9))-(0.0070*cos(2*15*3.14*(0.9-t)/0.9))-(0.9802*sin(2*3.14*(0.9-t)/0.9))-(0.5866*sin(2*2*3.14*(0.9-t)/0.9))-(0.2279*sin(2*3*3.14*(0.9-t)/0.9))-(0.0648*sin(2*4*3.14*(0.9-t)/0.9))+(0.0212*sin(2*5*3.14*(0.9-t)/0.9))+(0.2039*sin(2*6*3.14*(0.9-t)/0.9))+(0.0433*sin(2*7*3.14*(0.9-t)/0.9))+(0.0093*sin(2*8*3.14*(0.9-t)/0.9))-(0.0109*sin(2*9*3.14*(0.9-t)/0.9))-(0.0527*sin(2*10*3.14*(0.9-t)/0.9))-(0.0299*sin(2*11*3.14*(0.9-t)/0.9))-(0.0355*sin(2*12*3.14*(0.9-t)/0.9))-(0.0001*sin(2*13*3.14*(0.9-t)/0.9))+(0.0283*sin(2*14*3.14*(0.9-t)/0.9))+(0.0127*sin(2*15*3.14*(0.9-t)/0.9))); } end_f_loop(f,thread) } Thanks for the help, Anna |
September 5, 2013, 05:10 |
#2 | |
Pasquale Natale
I have had the same problem and I've solved it by using of dos2unix command. The problem, sometimes, is due to LF and CR special characters misunderstanding between the two O.S. and dos2unix helps to fix it. |
October 28, 2013, 08:33 |
#3 | |
Pasquale Natale
August 27, 2014, 12:23 |
Jens
Dear Anna,
I have encountered the same error on our system. I also tried to use dos2unix to resolve it, but it didn't work. So far, I suspect that it is related to a) the mounting of the file system that holds my working directory, or b) the C-preprocessor version used by Fluent. In my case, the file system is a non-unix (Windows), mounted using cifs-mount package. Working with Fluent 15 on some older SuSE 11 system, the error does not occur. On our newer Linux OS (SuSE Enterprise ...) the mount options are slightly different (due to the newer cifs package) and the error occurs. So I am convinced at least it has nothing to do with the source code of your UDF. If you have resolved the problem in the meantime, please let me know. Hopefully it will work here, too. Many thanks for a brief reply. Jens. |
November 18, 2015, 15:24 |
#5 | |
Rep Power: 10 |
November 18, 2015, 15:38 |
Rep Power: 10 |
April 10, 2017, 03:36 |
Hello, did anyone find a way to solve this problem?
#7 | |
Rep Power: 9 |
November 9, 2017, 16:59 |
Possible workaround
Bharat R Agrawal
Try these cases: 1) run the case in a directory that has the shortest possible path length, least depth in directory recursion and least possible number of non-alphanumeric characters in the path. 2) use the same cpp file that compiles the UDF file outside of Fluent but with the full command that Fluent uses, you may have to copy and modify a bunch of things.
December 12, 2017, 14:23 |
Thessaloniki
Hello!
I have exactly the same problem with the error below . Basically i am trying to start a computation via a journal file ,in which i try to interpret a udf. In windows i have no problem with execution but in cluster i get the error below . Is there anyone with a solution? 1. Dos2unix didn't help 2. #define _LARGEFILE_SOURCE 1 #define _LARGEFILE64_SOURCE 1 #define _FILE_OFFSET_BITS 64 #define FILESIZE ((int64_t)NUMINTS * sizeof(int)) didn't help either. Code:
cpp -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/main" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/addon-wrapper" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/io" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/species" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/pbns" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/numerics" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/sphysics" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/storage" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/mphase" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/bc" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/models" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/material" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/amg" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/util" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/mesh" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/udf" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/ht" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dx" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/turbulence" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/parallel" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/etc" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/ue" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dpm" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dbns" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/tgrid/src" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/cortex/src" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/client/src" -I"/opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/multiport/src" -I. -DUDFCONFIG_H="<udfconfig-host.h>" "1L_complete_UDF.c" /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/main/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/addon-wrapper/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/io/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/species/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/pbns/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/numerics/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/sphysics/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/storage/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/mphase/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/bc/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/models/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/material/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/amg/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/util/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/mesh/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/udf/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/ht/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dx/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/turbulence/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/parallel/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/etc/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/ue/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dpm/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/src/dbns/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/tgrid/src/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/cortex/src/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/client/src/.: Value too large for defined data type /opt/exp_soft/ansys_inc/v180/fluent/fluent18.0.0/multiport/src/.: Value too large for defined data type : Value too large for defined data type cpp: 1L_complete_UDF.c: Value too large for defined data type Error: "1L_complete_UDF.c": line 1: syntax error. |
September 30, 2018, 22:18 |
Javad Hashemi
The cpp that distributed with FLUENT is 32bit.
The error shown is typically associated to problems accessing specific directories in the fluent installation. It is a random failure, based on where Fluent is installed. You can solve this if you use /usr/bin/cpp instead of the cpp provided with installation, by setting the full path to cpp in GUI or TUI command. |
defined data type, large value, udf |
ERCOFTAC Centrifugal Pump with kOmegaSST Model | marcelgt87 | OpenFOAM Running, Solving & CFD | 4 | March 13, 2013 10:49 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
Instable natural convection case | Peter88 | OpenFOAM | 5 | August 18, 2011 01:23 |
turbulent jet simulation | antonio_ing | OpenFOAM Running, Solving & CFD | 5 | September 16, 2010 02:31 |
