UDF and UDM for heat transfer coeff. calculation |
May 3, 2013, 10:13 |
Christoph Schluckner
Rep Power: 12 |
First of all, I have to say that I´m totally new to UDF- programming. I´ve read several threads about this topic, but didn´t find anything suitable. My problem is as follows. I want to calculate the heat transfer coefficient between a condenser wall (with fixed temperature) and the surrounding water. My plan for writing my own udf is: read the specific heat flux q'' and temperature at the adjacent wall and read a characteristic fluid temperature somewhere near this wall. Then I would calculate the corresponding heat transfer coefficient for each cell. Following I would like to display the calculated results in a contour plot or something similar. I think this would be possible with a udm?! Attached you can see my geometry. It is a cyclic periodic 3D mesh. If somebody could be so nice and give me a small hint, how to do this, I would appreciate it very much. Thanks in Advance, christoph |
October 20, 2013, 13:39 |
Harshad
Rep Power: 12 |
Hi Christoph,
Have u got d problem solved? I m facing similar problem..... If u ve got it then please give me some hints.... Thanks |
Segmentation violation | louiza | FLUENT | 16 | June 27, 2017 15:41 |
UDF DPM_BC with F_UDMI not storing data | balki | Fluent UDF and Scheme Programming | 3 | June 6, 2016 22:10 |
Udm | nasser | FLUENT | 0 | April 7, 2013 09:19 |
Is possible to define an array like UDM in parallel udf? | supliu | Fluent UDF and Scheme Programming | 1 | March 20, 2013 03:29 |
