How to get a second derivative in udf?
Old   August 2, 2005, 06:09
Default How to get a second derivative in udf?
demigod
How to get a second derivative ( diff(T,z,2), where T is temperature, z is one dimensionality, 2 refers to the second derivative) in udf?
Thanks.
Old   August 3, 2005, 16:13
Default Re: How to get a second derivative in udf?
Laika
you must copy for each cell the first derivative of T in a UDM-location (at the end or after each iteration when needed). In postprocessing you can ask for the first derivative of this UDM, which is actually the desired second derivative.
As far as I know there is no other way.
good luck,
Laika, still orbiting
Old   August 3, 2005, 22:44
demigod
Thanks.
How can I get the first derivative of the defined UDM? by C_UDSI_G(c,t,i)?
Can I define an UDS to refer to first derivative of temperature [C_UDSI(c,t,0)=C_T_G(c,t)[2]] and use C_UDSI_G(c,t,0) to give the second derivative?
Thanks a lot.
the second derivative appears in the source term, so I must update its value by each iteration.
Old   August 9, 2005, 18:01
Laika
almost UDS --->c_UDSI(... UDM --->C_UDMI(...
the difference is that Fluent solves a transport equation for a UDS and not for a UDM. A UDM is just a memory location, but you can ask for the first derivatives. Hence the procedure:ask to calculate the first derivative of your quantity. Store it through the use of a UDF in a UDM, and ask for the first derivative of your UDM.
good luck,
Old   February 26, 2013, 11:41
Raymond.Leoi is on a distinguished road
Well, it seems C_UDMI_G(cell, thread, n) isn't accessible, but we can get C_UDSI_G(cell, thread, n). The problem I met is that those values of C_UDSI_G at cells attached with boundaries are wrong. Any idea to properly get it fixed or any other approach we can employ?
Originally Posted by Laika
;123159
good luck,
Raymond.Leoi is offline   Reply With Quote
Old   September 20, 2015, 13:27
Maryam-A is on a distinguished road
Hi every body
I wanted to return derivative of UDS as wall boundary value, but I faced with "fatal signal" while initializing (both Hybrid and standard) that I found this because of boundary condition UDS.
this is part of my udf for B.C of UDS( volume fraction of nanoparticle in my case)
DEFINE_PROFILE(alpha_bc1,thread,position)
Thread *t;
cell_t c;
begin_f_loop(f,thread)
C_UDSI_G(c,t,0)[0]=-(D_T/D_B)*C_T_G(c,t)[0];
F_PROFILE(f,thread,position)=C_UDSI_G(c,t,0)[0];
end_f_loop(f,t)
I would appreciate if anyone can help me about my mistakes.
Maryam-A is offline   Reply With Quote
Old   September 20, 2015, 13:34
Furthermore, I used Define_Adjust to calculate laplacian, maybe this is my fault?
can I use UDS as scalar variable and then I used it in source function?
I will turn off all Uds except one that I wanted to solve. is it true?
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDSI(c,t,1)=D_T*C_T_G(c,t)[0];
C_UDSI(c,t,2)=D_T*C_T_G(c,t)[1];
C_UDSI(c,t,3)=D_T*C_T_G(c,t)[2];
Laplacian=Laplacian+C_UDSI_G(c,t,1)[0]+C_UDSI_G(c,t,2)[1]+C_UDSI_G(c,t,3)[2];
C_UDSI(c,t,5)=dD_T*C_T_G(c,t)[0];
C_UDSI(c,t,6)=dD_T*C_T_G(c,t)[1];
C_UDSI(c,t,7)=dD_T*C_T_G(c,t)[2];
d_Laplacian=d_Laplacian+C_UDSI_G(c,t,4)[0]+C_UDSI_G(c,t,5)[1]+C_UDSI_G(c,t,6)[2];
C_UDSI(c,t,9)=D_D*C_T_G(c,t)[0];
C_UDSI(c,t,10)=D_D*C_T_G(c,t)[1];
C_UDSI(c,t,11)=D_D*C_T_G(c,t)[2];
LL=LL+C_UDSI_G(c,t,9)[0]+C_UDSI_G(c,t,10)[1]+C_UDSI_G(c,t,11)[2];
C_UDSI(c,t,13)=dD_D*C_T_G(c,t)[0];
C_UDSI(c,t,14)=dD_D*C_T_G(c,t)[1];
C_UDSI(c,t,15)=dD_D*C_T_G(c,t)[2];
dLL=dLL+C_UDSI_G(c,t,13)[0]+C_UDSI_G(c,t,14)[1]+C_UDSI_G(c,t,15)[2];
end_c_loop(c,t)
C_UDSI(c,t,4)=Laplacian;
C_UDSI(c,t,8)=d_Laplacian;
C_UDSI(c,t,12)=LL;
C_UDSI(c,t,16)=dLL;
Old   September 22, 2015, 04:43
pakk will become famous soon enough
Originally Posted by Maryam-A View Post
Hi every body
Thread *t;
cell_t c;
end_f_loop(f,t)
You ask Fluent what the value of "C_T_G(c,t)" is, but when you initialize, this value does not exist yet, so Fluent does not know what to do.
A workaround is to attach this boundary condition after initialization, not before.
pakk is offline   Reply With Quote
Old   September 28, 2015, 03:38
Hi
thankyou for advice.
I attached the B.C after initializing but no change is obtained. ):
How to build "Second Derivative " in UDF Bowling Fluent UDF and Scheme Programming 4 October 17, 2012 04:52
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
can i get pressure derivative in UDF? ruirui389 Fluent UDF and Scheme Programming 4 April 8, 2011 04:12
second derivative in udf dirk FLUENT 0 June 8, 2005 12:56
UDF for Second Derivative of Velocity Satish FLUENT 1 March 8, 2004 04:15
