Linking to fortran compiler in Windows
Old   May 13, 2014, 02:23
Default Linking to fortran compiler in Windows
Leanne R.
matth301 is on a distinguished road
I am running Fluent 15.0 on Windows 7 64 bit. I am trying to compile a UDF that references some Fortran subroutines. I have compiled the subroutines into a static library file, libmc.a. However, when I run nmake to compile the full UDF library, I get the following error:
Creating library libudf.lib and object libudf.exp
libmc.a(co2_reac_beamup.o) : error LNK2019: unresolved external symbol ___chkstk
_ms referenced in function co2_reac_beamup_
libmc.a(co2_reac_beamup.o) : error LNK2019: unresolved external symbol _gfortran
_st_write referenced in function co2_reac_beamup_
_transfer_real_write referenced in function co2_reac_beamup_
_st_write_done referenced in function co2_reac_beamup_
_transfer_character_write referenced in function co2_reac_beamup_
libmc.a(co2_reac_beamup.o) : error LNK2019: unresolved external symbol lround re
_transfer_integer_write referenced in function co2_reac_beamup_
libmc.a(randdp.o) : error LNK2019: unresolved external symbol trunc referenced i
n function __randdp_MOD_sdprnd
libudf.dll : fatal error LNK1120: 8 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 11.0
\VC\BIN\x86_amd64\link.EXE"' : return code '0x460'
When I have encountered similar errors on Linux, the solution was reference the Fortran compiler in the Makefile:
    $(LD) $(LDFLAGS) $(OBJECTS) $(USER_OBJECTS) -L/soft/gcc/4.7.2/lib64 -lgfortran -o $@
Does anyone know how to fix this error in Windows? I don't see a linking line in the Fluent UDF makefile for Windows. Thanks for any suggestions!
matth301 is offline   Reply With Quote
fortran subroutines, udf compilation
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 01:39
Fortran Compiler and example Young CFX 1 March 22, 2011 22:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Fortran compiler Erik Siemens 2 November 28, 2008 20:05
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 24, 2006 23:09
