Boiling and Condensation (Phase Change) UDF
Like Tree2Likes
  • 2 Post By SACHIN1639
Old   July 9, 2013, 11:02
Default Boiling and Condensation (Phase Change) UDF
Bin
Chan Hiang Bin
Bin is on a distinguished road
I'm new to ANSYS fluent, but I need to write udf for phase change including boiling and condensation in VOF model (which I think is a very difficult task for a newcomer like me). I had read through ANSYS UDF guide for some brief ideas. The following is what I think I need to write in the UDF after those readings (correct me if i'm wrong):
1. Define source terms in both liquid and vapor phases;
2. Define the mass transfer macro(where phase changes occur).
Is this correct? If I'm wrong what should I focus on? Any suggestions and advice are highly appreciate.
Best regards,
Bin
Bin is offline   Reply With Quote
Old   February 5, 2015, 04:08
Aayush
aayushjain27 is on a distinguished road
Hello friend i am trying to do the same. Have you got it done with this??
aayushjain27 is offline   Reply With Quote
Old   June 17, 2016, 09:26
SHUJAN
MDSHUJAN is on a distinguished road
Originally Posted by Bin View Post
Best regards,
Bin
Yes, you are right. You can do both way
MDSHUJAN is offline   Reply With Quote
Old   July 21, 2016, 09:44
SACHIN SHNDE
SACHIN1639 is on a distinguished road
#include "udf.h"
#include "sg_mphase.h"
#define T_SAT 373
#define LAT_HT 1.e3
DEFINE_SOURCE(liq_src, cell, pri_th, dS, eqn)
Thread *mix_th, *sec_th;
real m_dot_l;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
if(C_T(cell, mix_th)>=T_SAT)
m_dot_l = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)* fabs(C_T(cell, mix_th) - T_SAT)/T_SAT;
dS[eqn] = -0.1*C_R(cell, pri_th)*fabs(C_T(cell, mix_th) - T_SAT)/T_SAT;
else
m_dot_l = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)* fabs(T_SAT-C_T(cell,mix_th))/T_SAT; dS[eqn] = 0
return m_dot_l;
BlnPhoenix and tang17433 like this.
SACHIN1639 is offline   Reply With Quote
Old   January 22, 2017, 02:10
mehrdad
zakizadeh is on a distinguished road
Hi
I'm trying to simulate thermosyphon. But when the UDF read, and I want to run, the following error was printed!
please help
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
my email: zakizadeh.ac@gmail.com
zakizadeh is offline   Reply With Quote
UDF for condensation or boiling Yvonne Fluent UDF and Scheme Programming 12 June 24, 2019 16:57
Boiling and Condensation Ghalebsater FLUENT 0 February 1, 2012 22:59
boiling and condensation udf brusly FLUENT 0 January 8, 2007 22:33
udf for boiling and condensation brusly FLUENT 0 November 22, 2006 22:17
udf for boiling and condensation brusly FLUENT 0 November 20, 2006 01:10
