UDF for Pulsed flow
Like Tree2Likes
  • 1 Post By Vahidehzare1367
  • 1 Post By blackmask
Old   July 10, 2013, 03:08
Default UDF for Pulsed flow
Vahideh zare
Vahidehzare1367 is on a distinguished road
Hi all ,I’m new in fluent and particularly UDF, I want to model a system that a gas is inlet and it flows for 3s and doesn’t flow for 3s alternatively and continuously. I wrote a udf for this problem But it don't do correctly.
Please, guide me.
Thank you very much
#include"udf.h"
DEFINE_PROFILE(inlet_x_velocity, t, position)
face_t f;
real flow_time = RP_Get_Real(
"flow-time");
int i;
begin_f_loop(f, t)
for(i=0; i<=flow_time; i++)
if(flow_time >= i*6 && flow_time <= i*6 +3)
F_PROFILE(f,t ,position)=0;
else
F_PROFILE(f,t,position)=0.58425;
end_f_loop(f, t)
schlappeseppel124 likes this.
Vahidehzare1367 is offline   Reply With Quote
Old   July 10, 2013, 04:33
blackmask will become famous soon enough
Try this one.
#include"udf.h"
face_t f;
real flow_time = RP_Get_Real("flow-time");
int i = (int)(flow_time/3.0)%2;
begin_f_loop(f, t)
if( i)
else
end_f_loop(f, t)
blackmask is offline   Reply With Quote
Old   July 10, 2013, 05:09
Vahideh zare
Thank you very much in advance.
regards
Old   July 16, 2013, 02:19
Vahideh zare
Hi Blackmask, if I want to model a system that a gas is inlet and it flows for 0.05s and doesn’t flow for 0.05s alternatively and continuously, What do I do?
Old   July 16, 2013, 02:59
Change
to
int i = (int)(flow_time/0.05)%2;
tsram90 likes this.
Old   July 16, 2013, 03:17
Vahideh zare
I change this but the udf can't do correctly
Old   July 16, 2013, 03:31
Please explain in more details. What is the time step you choose in your calculation? Make sure that the time step is at least one order smaller that the period of the pulsating flow.
Old   July 16, 2013, 03:35
Yaser
Barzanoni is on a distinguished road
Hi Dear Vahideh
please see Chapter 8 of the ANSYS FLUENT UDF Manual.
vprofile.c
UDF for specifying steady-state velocity profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y, h;
face_t f;
h = 0.016; /* inlet height in m */
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
y = 2.*(x[1]-0.5*h)/h; /* non-dimensional y coordinate */
F_PROFILE(f, thread, position) = 0.1*(1.0-y*y);
end_f_loop(f, thread)
unsteady.c
UDF for specifying a transient pressure profile boundary condition
#include "udf.h"
DEFINE_PROFILE(unsteady_pressure, thread, position)
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f, thread)
F_PROFILE(f, thread, position) = 101325.0 + 5.0*sin(10.*t);
Barzanoni is offline   Reply With Quote
Old   June 10, 2016, 04:44
Default udf
adnan
adnan1000 is on a distinguished road
Hi all ,I’m new in fluent and particularly UDF, I want to model a system that a gas is inlet and it flows for 3s and doesn’t flow for 3s alternatively and continuously in steady state. I wrote a udf fo r this problem But it don't do correctly.
Please, guide me.
Thank you very much.
#include"udf.h"
face_t f;
int i = (int)(flow_time/1.0)%2;
begin_f_loop(f, t)
if( i)
else
F_PROFILE(f,t,position)=0. 2;
end_f_loop(f, t)
adnan1000 is offline   Reply With Quote
Old   June 10, 2016, 05:37
Bruno Machado
Bruno Machado is on a distinguished road
Please, guide me.
#include"udf.h"
face_t f;
begin_f_loop(f, t)
if( i)
else
end_f_loop(f, t)
you want to run a steady state or a transient case? you say one thing, but your problem suggests something different.
Bruno Machado is offline   Reply With Quote
Old   June 11, 2016, 03:38
adnan
The Model is a tube being inside water intermittent (pulse), but when I use the code is not there is a change in the results, When change my time
I do not know how or where I put the time flow
Old   March 20, 2018, 12:30
andreas_wan1 is on a distinguished road
hello, i'm currently try your code.. but it seems not working. could you please teach me how to write udf...?
andreas_wan1 is offline   Reply With Quote
Old   March 20, 2018, 14:33
pakk will become famous soon enough
"It seems not working" is not very helpful. Please be more detailed.
(Does it give errors? Warnings? Wrong results? Fluent crashes? Your computer destroyed in a fire? Nothing happened?)
pakk is offline   Reply With Quote
Old   March 20, 2018, 22:30
Thank you for you reply Sir..
so i was trying to simulate gas-solid fludized bed dryer with pulsed flow... 0.2 m/s inlet velocity in +y direction, frequency 1 Hz (
0s -> 0.5s it flow 0.2m/s
0.5s -> 1s the flow stop at 0 m/s
1.0s -> 1.5s the flow again at 0.2m/s , repeat continously
and when i simulate the volume fraction..it doesn't show any pulsed effect..more likely constant velocity..
i'm also trying to change the frequency into 3s flow...3s stop just to see wether the udf code is working properly or not..and it show the same..
here the copy of my udf code for 3S flow..3S stop flow
#include"udf.h"
DEFINE_PROFILE(inlet_y_velocity,t,position)
face_t f;
int i = (int)(flow_time/3)%2;
begin_f_loop(f,t)
if (i)
F_PROFILE(f,t,position)=0;
else
F_PROFILE(f,t,position)=0.2;
end_f_loop(f,t)
note: i still very beginner in fluent, especially in udf... so i don't know wether when we have to add "space" "." or ";" , and anything about coding
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
UDF for time-dependent flow borhan_sd@yahoo.com Fluent UDF and Scheme Programming 2 May 30, 2013 02:59
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
How to define mass flow rate using UDF? SAMUEL FLUENT 0 December 16, 2004 02:55
UDF for multiphase flow ROOZBEH FLUENT 3 April 7, 2004 17:54
