What is the opposite macro of C_ID(cell_t c,Thread*t)?
Old   July 26, 2013, 06:30
Default What is the opposite macro of C_ID(cell_t c,Thread*t)?
upeksa is on a distinguished road
I'm programming an UDF that stores cell index in serial or parallel with different number of nodes.
Using the macro C_ID(cell_t c,Thread*t), I can get in parallel use the same cell index as I had in serial use.
However, when I open my case each time with different number of nodes, I have different cell ID, although the global ID obtained with C_ID is the same.
What I want to do is the opposite of the marco C_ID: given the global cell ID as an input, I want to get the cell ID of my case, which will be different depending on the number of nodes.
Thanks in advance.
upeksa is offline   Reply With Quote
cell index, c_id, parallel, udf
StarCCM+ Command line options and Macro execution isidp STAR-CCM+ 8 January 29, 2013 05:00
Run macro for Multiple file furione STAR-CCM+ 6 November 28, 2011 14:54
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
Macro problem cfddummy Siemens 1 April 9, 2007 12:37
Call a macro from a macro Flav Siemens 2 July 1, 2004 05:42
