-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Compiling_define_udf (http://www.cfd-online.com/Forums/fluent-udf/121374-compiling_define_udf.html)
sayan_bose July 26, 2013 12:57
I am trying to define a velocity profile and a non-Newtonian viscosity model. The problem that I am facing is that when I am compiling it, after build it is showing in the console that the UDFs been copied but after loading it, it is not getting loaded. What should I do?
blackmask July 26, 2013 20:44
Post your UDF here. There should be some mistake preventing it from being compiled.
vasava July 29, 2013 02:34
Do you get 'The UDF library you are trying to load............' error?
If so there may be something wrong with your compiler/visual basic set-up.
sayan_bose July 30, 2013 11:29
Thank you for your reply..........................I think its either a problem with my compiler setup or may be virsu problems
vasava July 31, 2013 01:56
Do you have the windows SDK installed? If you have it, try loading fluent from SDK command window. If not I suggest that you install it. Without SDK compiling UDF will not work.
sayan_bose July 31, 2013 08:22
Thanks......but what is SDK?
vasava July 31, 2013 16:51
1 Attachment(s)
SDK is Software Development Kit. You need SDK 7 or 7.1 for udf compilation.
Please read this file. It might solve your problem.
