August 23, 2013, 05:55 |
help me check udf
tran trung
Rep Power: 12 |
hello every body
i have the udf #include "udf.h" #include "mem.h" /*global variables*/ real k = 722150.0; /*spring constant*/ real gravity = -9.81; /*gravity constant*/ real x_max=0.0085; /*the maximum lift is 8.5 mm*/ real f0=7126.0; /*initial spring force */ real mass=3.1928; /*spindle mass*/ real total_force=0.0; real pressure_force=0.0; /*the total hydraulic force over the entire spindle*/ real pressure_force1=0.0; /*hydraulic force beneath the disc, in contact with inlet*/ real pressure_force2=0.0; /*hydraulic force beneath the disc outside the seat*/ real pressure_force3=0.0; /*hydraulic force beneath the shroud*/ real pressure_force4=0.0; /*hydraulic force above the spindle */ real spring_force=0.0; real x= 0.000425; /*simulation starts with an opening of 0.425 mm*/ real velocity1=0.0; real velocity2=0.0; real massflow=0.0; real total_area1=0.0; real total_area2=0.0; real total_area3=0.0; real mass_flow1=0.0; real mass_flow2=0.0; real mass_flow3=0.0; real timestep=0.0; real dx=0.008075; real velocity =0.0; real total_time=0.0; real time_step=0.0; real pressure=0.0; real inlet_pressure=0.0; /************************************************** *********************************/ DEFINE_ADJUST(force_calculation,domain) { /* This function calculates the hydraulic forces acting on the spindle*/ int surface_thread_id1=26; int surface_thread_id2=30; int surface_thread_id3=31; int surface_thread_id4=32; pressure_force1=0.0; pressure_force2=0.0; pressure_force3=0.0; pressure_force4=0.0; #if !RP_HOST Thread *thread1; Thread *thread2; Thread *thread3; Thread *thread4; face_t face; /* an integer data type that indentifies a particular face within a face thread*/ real area[ND_ND]; /*get the thread pointer for which this motion is defined*/ thread1 = Lookup_Thread(domain,surface_thread_id1); thread2 = Lookup_Thread(domain,surface_thread_id2); thread3 = Lookup_Thread(domain,surface_thread_id3); thread4 = Lookup_Thread(domain,surface_thread_id4); /*compute pressure forces on body by looping through all faces*/ begin_f_loop(face,thread1) if (PRINCIPAL_FACE_P(face,thread1)) /* test if the face is the principle face*/ { F_AREA(area,face,thread1); pressure_force1+=area[2]*F_P(face,thread1); } end_f_loop(face,thread1) begin_f_loop(face,thread2) if (PRINCIPAL_FACE_P(face,thread2)) { F_AREA(area,face,thread2); pressure_force2+=area[2]*F_P(face,thread2); } end_f_loop(face,thread2) begin_f_loop(face,thread3) if (PRINCIPAL_FACE_P(face,thread3)) { F_AREA(area,face,thread3); pressure_force3+=area[2]*F_P(face,thread3); } end_f_loop(face,thread) begin_f_loop(face,thread4) if (PRINCIPAL_FACE_P(face,thread4)) { F_AREA(area,face,thread4); pressure_force4+=area[2]*F_P(face,thread4); } end_f_loop(face,thread4) pressure_force=pressure_force1+pressure_force2+pre ssure_force3+pressure_force4; #endif #if RP_NODE /*the value from all nodes are summed*/ pressure_force = PRF_GRSUM1(pressure_force); pressure_force1 = PRF_GRSUM1(pressure_force1); pressure_force2 = PRF_GRSUM1(pressure_force2); pressure_force3 = PRF_GRSUM1(pressure_force3); pressure_force4 = PRF_GRSUM1(pressure_force4); #endif 64 /*the data from the nodes is sent to the host*/ node_to_host_real_5(pressure_force,pressure_force1 , pressure_force2, pressure_force3, pressure_force4); /************************************************** ******************************/ DEFINE_ADJUST(velocity_calculation,domain) { int surface_thread_id1=5; int surface_thread_id2=34; int surface_thread_id3=13; total_area1=0.0; total_area2=0.0; total_area3=0.0; mass_flow1=0.0; mass_flow2=0.0; mass_flow3=0.0; #if !RP_HOST Thread *thread1; Thread *thread2; Thread *thread3; face_t face; real area[ND_ND]; thread1 = Lookup_Thread(domain,surface_thread_id1); thread2 = Lookup_Thread(domain,surface_thread_id2); thread3 = Lookup_Thread(domain,surface_thread_id3); begin_f_loop(face,thread1) if (PRINCIPAL_FACE_P(face,thread1)) { F_AREA(area,face,thread1); total_area1 += NV_MAG(area); mass_flow1+=F_FLUX(face,thread1); } end_f_loop(face,thread1) begin_f_loop(face,thread2) if (PRINCIPAL_FACE_P(face,thread2)) { F_AREA(area,face,thread2); total_area2 += NV_MAG(area); mass_flow2+=F_FLUX(face,thread2); } end_f_loop(face,thread2) begin_f_loop(face,thread3) if (PRINCIPAL_FACE_P(face,thread3)) { F_AREA(area,face,thread3); total_area3 += NV_MAG(area); mass_flow3+=F_FLUX(face,thread3); 65 } end_f_loop(face,thread3) #endif #if RP_NODE mass_flow1 = PRF_GRSUM1(mass_flow1); mass_flow2 = PRF_GRSUM1(mass_flow2); mass_flow3 = PRF_GRSUM1(mass_flow3); total_area1 =PRF_GRSUM1(total_area1); total_area2 =PRF_GRSUM1(total_area2); total_area3 =PRF_GRSUM1(total_area3); #endif massflow=mass_flow1; node_to_host_real_1(massflow); } /************************************************** *****************************/ DEFINE_CG_MOTION(spindle, dt, vel, omega, time, dtime) { /*reset velocities*/ NV_S(vel, =, 0.0); NV_S(omega,=, 0.0); /*no angular motion*/ /*set y-component of velocity*/ vel[2] = velocity; /*variable needed in execute_at_end*/ timestep=dtime; } /************************************************** ******************************/ DEFINE_EXECUTE_AT_END(Velocity) { /*Calculation of velocity*/ real dv=0; real gravity_force=0.0; spring_force=0.0; /* calculate the total force acting on the spindle*/ gravity_force = mass*gravity; /*calculate the spring force*/ spring_force = -k*x - f0; /*calculate the total hydraulic force since mirror symmetry is used*/ pressure_force=pressure_force*2; total_force=pressure_force + gravity_force + spring_force; dv = timestep * total_force/mass; velocity+=dv; 66 /*Restriction: stop at lift=8.5 mm*/ if (dx < 0) { velocity=0; Message("\nThe valve is fully open!"); } /*Restriction: stop if the valve is closed*/ if (dx > 0.008074) { if (total_force<0) { velocity=0; Message("\nThe valve is fully closed"); } } } /************************************************** ********************/ DEFINE_EXECUTE_AT_END(lift_movement) { /*Calculation of the spindle position*/ x+=timestep*velocity; dx=x_max-x; Message("\nThe spindle has moved %f\n", x); total_time+=timestep; } /************************************************** ********************/ DEFINE_EXECUTE_AT_END(saving_values) { #if RP_NODE if(myid==0) { FILE *data; data = fopen("data_SST_second_order_34bar_igen.txt", "a"); fprintf(data,"%f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\t %f\n", total_time, velocity, x, pressure_force1, pressure_force2, pressure_force3, pressure_force4, pressure_force, spring_force, total_force, inlet_pressure, velocity1, velocity2, massflow); fclose(data); } #endif } when complied function udf i get error valuue.c ..\..\src\valuue.c(46) : error C2275: 'Thread' : illegal use of this type as an expression C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\src\ mem.h(792) : see declaration of 'Thread' ..\..\src\valuue.c(46) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(47) : error C2275: 'Thread' : illegal use of this type as an expression C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\src\ mem.h(792) : see declaration of 'Thread' ..\..\src\valuue.c(47) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(48) : error C2275: 'Thread' : illegal use of this type as an expression C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\src\ mem.h(792) : see declaration of 'Thread' ..\..\src\valuue.c(48) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(49) : error C2275: 'Thread' : illegal use of this type as an expression C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\src\ mem.h(792) : see declaration of 'Thread' ..\..\src\valuue.c(49) : error C2065: 'thread4' : undeclared identifier ..\..\src\valuue.c(50) : error C2275: 'face_t' : illegal use of this type as an expression C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\src\ mem.h(196) : see declaration of 'face_t' ..\..\src\valuue.c(50) : error C2146: syntax error : missing ';' before identifier 'face' ..\..\src\valuue.c(50) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(52) : error C2275: 'real' : illegal use of this type as an expression c:\program files\ansys inc\v140\fluent\fluent14.0.0\src\global.h(175) : see declaration of 'real' ..\..\src\valuue.c(52) : error C2146: syntax error : missing ';' before identifier 'area' ..\..\src\valuue.c(52) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(52) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(54) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(54) : warning C4047: '=' : 'int' differs in levels of indirection from 'Thread *' ..\..\src\valuue.c(55) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(55) : warning C4047: '=' : 'int' differs in levels of indirection from 'Thread *' ..\..\src\valuue.c(56) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(56) : warning C4047: '=' : 'int' differs in levels of indirection from 'Thread *' ..\..\src\valuue.c(57) : error C2065: 'thread4' : undeclared identifier ..\..\src\valuue.c(57) : warning C4047: '=' : 'int' differs in levels of indirection from 'Thread *' ..\..\src\valuue.c(59) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(59) : error C2223: left of '->nelements' must point to struct/union ..\..\src\valuue.c(59) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(59) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(59) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(62) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(62) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(62) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(62) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(62) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(62) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(62) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(62) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(62) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(62) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(62) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(62) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(62) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(62) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(62) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(63) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(63) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(63) : error C2065: 'thread1' : undeclared identifier ..\..\src\valuue.c(63) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(63) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(66) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(66) : error C2223: left of '->nelements' must point to struct/union ..\..\src\valuue.c(66) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(66) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(66) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(69) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(69) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(69) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(69) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(69) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(69) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(69) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(69) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(69) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(69) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(69) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(69) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(69) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(69) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(69) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(70) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(70) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(70) : error C2065: 'thread2' : undeclared identifier ..\..\src\valuue.c(70) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(70) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(73) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(73) : error C2223: left of '->nelements' must point to struct/union ..\..\src\valuue.c(73) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(73) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(73) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(76) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(76) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(76) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(76) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(76) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(76) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(76) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(76) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(76) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(76) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(76) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(76) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(76) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(76) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(76) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(77) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(77) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(77) : error C2065: 'thread3' : undeclared identifier ..\..\src\valuue.c(77) : error C2223: left of '->storage' must point to struct/union ..\..\src\valuue.c(77) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(80) : error C2065: 'thread4' : undeclared identifier ..\..\src\valuue.c(80) : error C2223: left of '->nelements' must point to struct/union ..\..\src\valuue.c(80) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(80) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(80) : error C2065: 'face' : undeclared identifier ..\..\src\valuue.c(83) : error C2065: 'area' : undeclared identifier ..\..\src\valuue.c(83) : error C2109: subscript requires array or pointer type ..\..\src\valuue.c(83) : fatal error C1003: error count exceeds 100; stopping compilation Done. what do you do ? thank you |
Display Modes | |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
