October 16, 2013, 02:31 |
dynamic contact angle - oil & water
Rams Manu
Rep Power: 12 |
I am trying to model the movement of water droplets on a layer of oil coated on an inclined plane (so that there is a body force on oil as well as water droplets) First of all, there is no option in fluent for imposing a contact angle between two phases (oil and water) other than at wall. . Next, I couldn't find a proper way through UDF to impose a dynamic contact angle on the water droplets moving over the oil ! Although I can impose the dynamic contact angle on water droplets moving over a wall, is it possible to apply the contact angle at the oil surface rather than at wall ? Or is fluent capable of imposing the dynamic contact angle between oil and water by itself ? (which I highly doubt so but still I can see some convincing results after the simulations so far without a UDF!) Any kind of help would be really appreciated, coz I am stuck here for quite a bit of time. Manxu |
dynamic contact angle, oil, water droplet |
Simulation of varying contact angles for a large droplet of water on a surface | cp703 | CFX | 5 | July 20, 2013 06:08 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 13:58 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
