October 12, 2013, 00:48 |
Urgent help needed in creating UDF's
Sharath Chandra. J
Rep Power: 12 |
I am currently working on validation of a small project and it includes flow conditions in parabolic profile and temperature conditions varying in a linear fashion increasing along the Y axis.
Velocity varies as u(y)=12(y-(y^2)) and y ranges from -1/6 to 1/2 Temperature varies as θ(y)=(1-2y) and again y ranges from-1/6 to 1/2 My main problem is i don't understand how to define the centre-line velocity i.e maximum velocity and temperature conditions. Also from a previous experience, I couldn't include two different UDF's for different boudary conditions. Is it possible to write both the UDF's in a single program I have included all the required data probably. In case anything else is required, I would respond. Please help me out. |
October 12, 2013, 10:55 |
#2 | |
Rick
Rep Power: 26 |
Please define your equations; if I plot the velocity equation between -1/6 and 1/2 I have negative velocities and the profile of the parabola is not complete. If I translate the parabola and if I plot that translated parabola the profile of the parabola is not complete. Do the same with the T equation. Can you define better your problem? Daniele |
October 12, 2013, 14:12 |
RE: Data clarification
#3 | |
Sharath Chandra. J
Rep Power: 12 |
The problem I am working on is a backward facing step flow with varying expansion ratios. I have to validate the flow conditions in the problem for varying ratios of S/H as shown form the figure. From the paper I've been trying to validate this sentence is verbatim. " The physical domain in the X-direction is bounded by 0 < x < (30H) and in the y direction it is bounded by –S/DH < y < 1/2.If having the Reynolds number of the flow would be helpful, then it is 800 and the fluid is assumed as water with standard properties. |
temperature bc, udf, velocity bc |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 16:22 |
Parse error in UDF, URGENT HELP NEEDED!!! | Boris Kloser | FLUENT | 2 | December 12, 2009 04:16 |
help needed in Turbulent flow (URGENT) | mike | FLUENT | 7 | November 7, 2008 07:11 |
Urgent help needed with spray injection | nick | Siemens | 14 | June 29, 2008 19:48 |
Urgent Help Needed! | Ken Adams | FLUENT | 3 | September 26, 2007 00:50 |
