UDF for radial expansion
Like Tree1Likes
  • 1 Post By kenan
Old   July 21, 2013, 12:54
Default UDF for radial expansion
kenan is on a distinguished road
Hello all,
I have a simple 2D circle meshed with tetra elements. I want this circle to expand radially. For that purpose i have written the code below, using DEFINE_GRID_MOTION. This code gets face unit normal vectors on boundary, and tries each node to move through this unit vector of the face which it belongs to. However Fluent gives the error " Left handed faces detected! ". I dont know how to handle this problem. Any help would be kindly appreciated.
/* Expansion-Contraction through face normal unit vector */
#include "udf.h"
DEFINE_GRID_MOTION(radial-expansion, domain, dt, time, dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real displ;
real A[ND_ND]; /* face area normal vector */
real AMag; /* face area magnitude */
real NV_VEC(e); /* face unit normal vector */
int n;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
displ=5*dtime;
begin_f_loop(f, tf)
AMag=NV_MAG(A);
NV_VS(e,=,A,/,AMag); /* face unit normal vector */
f_node_loop(f,tf,n)
v=F_NODE(f,tf,n);
if (NODE_POS_NEED_UPDATE(v))
NODE_POS_UPDATED(v);
NV_V_VS(NODE_COORD(v),=, NODE_COORD(v), +, e, *, displ);
kenan is offline   Reply With Quote
Old   July 21, 2013, 16:54
Finally i have managed it, even with a 3D cylinder. I used position vector of each node, instead of face normal vector. I eliminate the z component of the position vector, in order to get uniform expansion (equal displacement for all nodes) for a 3-D cylinder (The central axis of the cylinder is z axis).
However, i still wonder how i could get a uniform expansion; if i would have, for example, an ellipsoid or a sphere.
Minnu likes this.
Old   October 16, 2013, 09:14
Vit Prokop
kure87 is on a distinguished road
Hi, if it's help here is my code for normal expansion (respective fluctuation) of the surface in the Ansys Fluent. I used it for creation of the pressure waves and sound propagation excited by oscilating part.
Tested on the sphere, more complicated test will follow in next few days.
   NormalExpansionSurface.c
  UDF for specifying a transient expansion of the mesh, normal to its face
#include "udf.h"
DEFINE_GRID_MOTION(NormalExpansion3, domain, dt, time, dtime)
face_t f;
Node *v;
real displ;
real NV_VEC(axis);
int n;
displ=-0.002388*cos(6280*(time+0.00025)); //grid displacement
begin_f_loop(f, tf)
f_node_loop(f,tf,n)
F_AREA(A,f,tf);   /*A is a vector, f face index, t thread index */
AMag=NV_MAG(A); /* Face normal vector */
A[0]=A[0]/AMag; /* X component of vector */
A[1]=A[1]/AMag; /* Y component of vector */
A[2]=A[2]/AMag; /* Z component of vector */
NV_D(axis, =, A[0], A[1], A[2]);
v=F_NODE(f,tf,n);
NV_V_VS(NODE_COORD(v), =, NODE_COORD(v), +, axis,*,displ);
end_f_loop(f,tf);
kure87 is offline   Reply With Quote
Old   October 16, 2013, 10:59
Hi kure87,
Thank you for your reply. Actually we have sought for almost-proper expansion of left ventricle of human heart. It is difficult to preserve the approximate shape of the LV after applying expansion operation.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
