DEFINE_CG_MOTION vs DEFINE_GRID_MOTION
Like Tree1Likes
Old   August 28, 2012, 11:02
Default DEFINE_CG_MOTION vs DEFINE_GRID_MOTION
cfd seeker is on a distinguished road
I am trying to simulate the flapping motion of simple wing using a UDF. I came across two types of UDF's for the said purpose. I would like to know the difference between the two types and which one is better if we want to simulate flapping/pitching/twisting/rolling motion of the wing. Thanks in advance
Regards
cfd seeker is offline   Reply With Quote
Old   August 30, 2012, 01:46
Amir's Avatar
Amir
Amir is on a distinguished road
Dear friend,
DEFINE_GRID_MOTION macro is more general than DEFINE_CG_MOTION. with DEFINE_CG_MOTION macro you can just define a rigid body motion but with DEFINE_GRID_MOTION macro you can describe the motion of each computational node.
Bests,
Chong070940103 likes this.
Amir
Amir is offline   Reply With Quote
Old   September 3, 2012, 14:20
Thanks Amir for your reply. I am currently doing CFD analysis of flapping wing for which I have a UDF but there are some problems in that and its not working properly. I will share my UDF here in a day or two and will need your help to remove errors from it. Thanks
Old   September 7, 2012, 11:49
Hi guys I am back with my UDF I want to simulate flapping motion of wing. The wing goes up from the mean position, comes back to the mean position and completes the half cycle in opposite direction. Here instead of going up, it again goes down and keep on flapping between mean position and downward direction which ofcourse is wrong. I am not able to figure out the mistake in the UDF. Kindly I need the help to correct it. Thanks in advance
#include "udf.h"
DEFINE_GRID_MOTION(s1020, domain, dt, time, dtime)
Thread *tf = DT_THREAD (dt);
face_t f;
Node *v;
real NV_VEC(omega), NV_VEC(axis), NV_VEC(dp);
real NV_VEC(origin), NV_VEC(rvec);
real sign, terma, PI;
int n;
/* set deforming flag on adjacent cell zone */
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
terma = 26.178*time;
sign = -1 * sin (26.178 * time);
Message (" terma = %10.7f\n",terma);
Message (" time = %10.5f, sign = %10.5f \n", time, sign);
PI = 3.141592654;
/* if ( terma>PI )
sign = -sign;
NV_S(omega, =, 0.0);
NV_D(axis, =, 1.0, 0.0, 0.0);
NV_D(origin, =, 0.5, 0.0, 0.0);
Message (" axis = %10.5f, origin = %10.5f \n", axis, origin);
begin_f_loop(f, tf)
f_node_loop(f, tf, n)
v = F_NODE(f, tf, n);
/* update node if z position is greater than 0.02 and that the current node */
/* has not been previously visited when looping through previous faces */
if (NODE_Z(v) > 0.02 && NODE_POS_NEED_UPDATE (v))
/* indicate that node position has been update so taht it's not */
/* updated more than once */
NODE_POS_UPDATED(v);
omega [0] = sign * pow (NODE_Z(v)/4, 0.5);
NV_VV(rvec, =, NODE_COORD(v), -, origin);
NV_CROSS(dp, omega, rvec);
NV_S(dp, *=, dtime);
if ( terma>(2.*PI) )
NV_V(NODE_COORD(v), -=, dp);
else
NV_V(NODE_COORD(v), +=, dp);
end_f_loop(f, tf);
Old   September 7, 2012, 11:52
I am attaching the txt file of the UDF in case any body wants to open it in C
Old   September 8, 2012, 03:47
Amir's Avatar
Amir
If just the direction is the issue, I solved it for my previous UDFs in this manner:
Suppose you know the magnitude of omega, A and the period is T; so you can do something like this:
dd=T/4;
time1=time;
time=time1/dd;
time=time1-((int)time)*dd;
if (time1<=dd)
	dtheta=A*dtime
else
	time2=(time1-dd)/(2.0*dd);
	m=((int)time2)+1;
	dtheta=pow(-1,m)*A*dtime;
i.e., you need to generate this sequence: +1,-1,-1,+1,+1,-1,-1,....
Hope that help.
Bests,
Amir
Old   September 8, 2012, 10:11
Originally Posted by Amir View Post
dd=T/4;
time1=time;
time=time1/dd;
if (time1<=dd)
	dtheta=A*dtime
else
	m=((int)time2)+1;
Hope that help.
Bests,
Thanks Amir for your reply. I am just a beginner in UDF's and some one helped me to modify the UDF in the current shape. So i don't know much about UDF's and C, can you kindly suggest me where I am going wrong in my UDF and where to incorporate the lines suggested by you . Thanks
Old   September 8, 2012, 17:11
Amir's Avatar
Amir
It seems the problem is here:
else
These conditions are not appropriate to model your movement properly.
To correct your code, you have to change your code in this manner:
period=2.0*PI/(26.178);
if (time<=(period/4.0))
	NV_CROSS(dp, abs(omega), rvec);
else
	time2=(time-(period/4.0))/(period/2.0);
	m=((int)time2)+1;
        NV_CROSS(dp, abs(omega)*pow(-1,m), rvec);
Substitute it in proper lines. (It may need additional changes in its format)
P.S. : We're here to help you figure out and eliminate the issues by yourself not to give you the final answer.
Bests,
Amir
Old   September 12, 2012, 10:50
nclude "udf.h"
face_t f;
Node *v;
real sign, terma, PI,period;
int n,time2,m;
PI = 3.141592654;
/* if ( terma>PI )
sign = -sign;
begin_f_loop(f, tf)
/*NV_CROSS(dp, omega, rvec);
if ( terma>(2.0*PI) )
else
NV_V(NODE_COORD(v), +=, dp);*/
period=2*PI/(26.178);
NV_CROSS(dp,omega, rvec);
else
m=((int)time2)+1;
NV_S(omega,*=,pow(-1,m));
NV_CROSS(dp,omega), rvec);
end_f_loop(f, tf);
I have made the fallowing changes but UDF still not working, kindly take out sometime and have a look at it and suggest something.....
Old   September 12, 2012, 15:26
Amir's Avatar
Amir
int time2!!!
Amir
Old   September 12, 2012, 22:07
sorry Amir the mistake you pointed out was corrected in the original UDF but still its not working....I dont know what's happening in the changed version but the amplitude of the wing becomes so high that it becomes almost vertical and never comes back
Old   September 13, 2012, 04:07
Amir's Avatar
Amir
Maybe it's better to write the amplitude or omega in file to see where to change the code.
Bests,
Amir
Old   September 13, 2012, 05:57
Bests,
Sorry didn't get the point? please explain.....
period=2.0*PI/(26.178); if (time<=(period/4.0)) { NV_CROSS(dp, abs(omega), rvec); } else { time2=(time-(period/4.0))/(period/2.0); m=((int)time2)+1; NV_CROSS(dp, abs(omega)*pow(-1,m), rvec); }
In the above commands I am not able to use "abs" with omega to get the absolute value of omega, every time I use the command "abs" fluent gives error....so is this thing causing problem or what else?
Old   September 13, 2012, 05:59
So instead of "abs(omega)" I am only using "omega"...is this thing causing problem or what else?
Old   September 13, 2012, 10:15
Frederik
fchan is on a distinguished road
Did you include math.h?
fchan is offline   Reply With Quote
Old   September 13, 2012, 10:30
no i didn't....is it necessary?
Old   September 13, 2012, 11:41
Frederik
Yes! Also, use fabs() instead of abs() for float/double variables.
Quick google: http://www-control.eng.cam.ac.uk/~pc...h_details.html
TL;DR: add #include <math.h>
Good luck.
Old   September 13, 2012, 21:47
Thanks fchan for your help. Have you seen my UDF? is everything ok except this?
Old   September 14, 2012, 01:52
Good luck.
its not necessary to include <math.h> in UDF's. I read it today. It is necessary to include math.h IN "C" but its not necessary in UDF. Something else is wrong with my UDF.....
Old   September 14, 2012, 09:24
Amir's Avatar
Amir
Store the value of omega/amplitude in a file in different times and check where the issue is.
That's the general idea and it may need changes in its format; I'm not sure, maybe using functions in NV commands are not allowed; store abs(...) in a temporary variable and use that in NV command instead.
Bests,
Amir
