UDF: saving multiple files
Old   March 3, 2014, 09:33
Default UDF: saving multiple files
Persil is on a distinguished road
hello guys,
with this UDF I want to save 42 interpolation files of a case that will be rotated by a certain angle every loop. The problem is, that when rading the journal it only saves vane1.ip and does not continue the loop... is there a syntax error somewhere or any other mistake?
(define string0 " ..................... ROUND ")
(define string1 "vane")
(define string2 ".ip" )
;======== write interpolation
f inter zs
vane_fluid
f inter w-d
vane1.ip
yes
(do ((i 2 (+ i 1))) ((> i 42))
(begin
(define zahl (number->string i))
(define round (string-append string0 zahl "/42" ))
(define file (string-append string1 zahl string2))
(display "\n\n\n\n")
(display round)
(display "\n\n")
(ti-menu-load-string (format #f "
gr rot 8.571428571 0 0 0 -1 0 0
(display round)
(display "\n\n")
f inter w-d vane~d.ip yes
" i))
any help is appreciated, thx
Persil is offline   Reply With Quote
Old   March 3, 2014, 10:17
pakk will become famous soon enough
For future reference: this is not a UDF, but a scheme script. You still asked the question at the right place .
pakk is offline   Reply With Quote
controlDict 'forces' function: multiple output files? lordvon OpenFOAM 0 January 10, 2011 16:22
Calculating YPLUS and Compiling Multiple C files sanjibdsharma OpenFOAM Programming & Development 1 August 11, 2009 06:56
UDF for reading dat files mrestrepo30 FLUENT 0 July 8, 2009 09:10
rotary vane pump udf files R.SRIHARI Main CFD Forum 1 February 27, 2009 09:25
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
