November 29, 2012, 23:55 |
UDS source term
Mukesh
Rep Power: 13 |
Dear all,
I need little help to write my UDS source term. My equation represents reaction rate and is represented as: (dX/dt) = k_a*e^(-Ea/(R_u*T))*((P_i - P_eq)/P_eq)*(1-X) where, X is concentration at any time instant 't' [0< X <1] k_a is reaction constant E_a is activation energy (Constant) R_u is universal gas constant T is temperature of cell P_i is initial supply pressure (constant) P_eq is equilibrium pressure (dependent on 'T') defined as ln(P_eq) = (DELTA_S/R_u)-(DELTA_H/(R_u*T)) Here, DELTA_S & DELTA_H are again constants R_u & T are as defined above. I wrote this, But it doesn't seem to work properly as the temperature of my domain vary radially (an annular cylinder) and hence reaction rate is different at different radii, Ideally as 'x' reaches '1' reaction should stop but when I plot 'X' contours it shows values > 1 in colder regions (suggesting reaction continues even after reaching a value >1) as this should't be. Code:
DEFINE_UDS_UNSTEADY(uds_time,c,t,i,apu,su) { real physical_dt; real vol; real rho; real phi_old; physical_dt = RP_Get_Real("physical-time-step"); vol = C_VOLUME(c,t); rho = 1; *apu = -rho*vol/physical_dt; phi_old = C_STORAGE_R(c,t,SV_UDSI_M1(0)); *su = rho*vol*phi_old/physical_dt; } /* Kinetic Equation SOURCE term */ /* Convection & Diffusion part are zero */ DEFINE_SOURCE(uds_source,c,t,ds,eqn) { real tp; real rate; real P_eq; real cond; tp = C_T(c,t); P_eq = pow(10,5)*pow(2.72,((DELTA_S/R_u)-(DELTA_H/(R_u*tp)))); C_UDMI(c,t,0)= P_eq; cond = P_i/P_eq; if(cond>1) { rate = k_a*pow(2.72,(-E_a/(R_u*tp)))*((P_i/P_eq)-1)*((C_UDSI_M1(c,t,0) - x_f)/(x_i - x_f)); ds[eqn] = k_a*pow(2.72,(-E_a/(R_u*tp)))*((P_i/P_eq)-1)*(1/(x_i - x_f)); /* Derivative of SOURCE w.r.t. DEPENDENT variable */ } else { rate = 0; ds[eqn] = 0; } C_UDMI(c,t,1) = rate; return rate; } |
December 6, 2012, 05:59 |
UDS source is not returning value to Energy source term
Mukesh
Rep Power: 13 |
Someone please help!
What I figured out was my UDS source is calculating values for various cells but I guess it is not returning the values to energy source term. What could be the reason. Monitoring 'rate' (UDS source) shows variations spatially (as temperature is varying spatially) But this variation is not taken up by the Energy source term although it is directly dependent on the 'rate' (UDS source). Please, please ......someone help me out. |
January 29, 2013, 11:51 |
#3 | |
Jeremiah Lin
January 31, 2013, 16:26 |
Mukesh
Rep Power: 13 |
Hello Lin,
Sorry I didn't updated the status on my work. And yes you are correct to suggest using UDM. I solved the problem using UDM. Thanks. Regards, Mukesh |
January 14, 2014, 04:06 |
#5 | |
Long Nguyen
Rep Power: 12 |
I'm working on the model of hydrogen storage by metal hydride. So, I'm very confused about the UDF code for source term. Could you share with me your UDF code just for reference? Thank you very much Regards, Long Nguyen |
source term, uds source |
UDS source term units | Ale | FLUENT | 3 | March 29, 2017 07:08 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
Large source term in species equation | MACFD | FLUENT | 4 | January 4, 2011 14:16 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
