steady state for a standing ultrasonic wave
I intend to simulate an ultrasonic standing wave by using an pressure inlet with a reflector. The pressure inlet is supposed to oscillate sinusoidal to generate the wave. Now the question: Is it possible to generate the steady state by using a .ttab profile while the time step size is much larger than the profile step sizes?
Do I need to calculate in the same time step size as the profile step size is? What could be the alternative to simualte this if Iīm only interested in the steady state and therefore donīt want to calculate in the transient mode? Thanks a lot! |
1 Attachment(s)
Hello flueth,
have you been able to generate te ultrasonic wave? am actually facing similar problem : i want to simulate the ultrasonic field generated by 2 transducers mounted on a pipe with streaming water. please see attached.. i would be thankful for help :) Attachment 43739 http://www.cfd-online.com/Forums/<if...uot;></iframe> http://www.cfd-online.com/Forums/<if...uot;></iframe> |
I don't know if this can be simulated in steady state: from my point of view, no, because in a standing wave, waves continuously interact..If you look at the transducer it will never reach a steady state, as it continues to oscillate.
I simulated in the past simple ultasonic waves in water, in 2d and 3d, with the approach of a udf, compiled with the DEFINE_GRID_MOTION macro: this means you must know the displacement that your transducer produces. |
what is udf? i am actually intending to set up the simulation for openfoam. All i know about the transducer is that the emitted wave frequency is about 1MHz and some other information related to emitted longitudinal and transversal waves. Do you mean with Displacement the wave height on a free surface of water? Best regards Houssam. |
I mean the dispacement of the tip of the transducer or of the plate.
I was inspired by this article (from page 5 of the pdf): http://www2.arnes.si/~mdula/Numerica...ic%20field.pdf Maybe it can help. Udf is a user define function, to expand the capabilities of fluent. Maybe you can look at the openfoam section of this forum. |
ah ok. My plan was to define a sinusoidal pressure BC at the tranducer location. You are right it seems to make more sense to rather define a periodic displacement somehow.. the journal's paper seems to be interesting. I have also to take the generated acoustic cavitation into account because it will affect the fluid proporties (density, viscosity) and hence the wave propagation velocity ..
have you used a dynamic mesh for your simulations? |
Yes, the DEFINE_GRID_MOTION" defines o moving/deforming mesh.
I also included liquid compressiblity, by including an udf for density and speed of sound. |
sounds good.
Surely i have also to define appropriate functions in OpenFoam. Unfortunately there are here no threads discussing the issue for openfoam. I would be very thankful if i could have a look into your udf ghost82 :) |
ultrasonic waves
I connected transducer from upstream and downstream sides how can i define its boundary conditions? |
hello there
I wanna simulating a ultrasonic probe in fluent with moving mesh can you help me with your experience thanks |
