UDF FOR PIPE Two phase flow
Old   March 7, 2014, 07:33
Default UDF FOR PIPE Two phase flow
ahmed ibraheem
ahmedsh974 is on a distinguished road
Hello for all
I need UDF at velocity inlet for two phase flow ( oil-water) horizontal pipe
D= 0.014 m
L= 3.5 m
velocity oil = 0.09 m/s
velocity water = 0.3 m/s
volume friction of water is = 77 %
thank you
ahmedsh974@gmail .com
ahmedsh974 is offline   Reply With Quote
Old   March 15, 2014, 21:37
Ali Kiani
alikiani is on a distinguished road
you dont need a udf file. adjust your volume fraction (0.77) to inlet an set 0.39 m/s for your inlet.
alikiani is offline   Reply With Quote
Old   April 15, 2020, 19:13
Default How to get Phase velocity from mixture velocity data
Abhi
abhilasht is on a distinguished road
I`m having multiphase simulation of nanofluid passing through a horizontal pipe using Mixture-model. How to assign phase velocities in velocity inlet condition as I`m having mixture velocity data only. Is a UDF is required for phase velocity? Kindly help.
abhilasht is offline   Reply With Quote
Gravity/Buoyancy/Buoyancy reference density in two phase flow sharifi CFX 10 June 9, 2014 10:23
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 07:33
UDF of "anisotropic phase function" in radiation modeling whiz Fluent UDF and Scheme Programming 0 September 1, 2009 03:26
UDF of two phase flow : drag coefficient superxeonman FLUENT 0 May 21, 2008 21:53
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
