UDF for CG_motion
Old   March 10, 2014, 11:04
Default UDF for CG_motion
Linh Tuan The Nguyen
linh nguyen is on a distinguished road
I am Linh. I quite new with using UDF. I was writing this UDF using CD_MOTION Macro.
My objective is solve the amplitude of motion for single degree of freedom using Finite different method. But I have two errors:
- syntax error : missing ';' before 'type'
- subscript is not of integral type.
Here is my UDF code.
#include "udf.h"
#include "stdio.h"
#include "stdlib.h"
#include "math.h"
#include "dynamesh_tools.h"
#include "storage.h"
static real v_prev = 0.0;
FILE *fout;
DEFINE_CG_MOTION(cylinder, dt, vel, omega, time, dtime)
Thread *t;
Domain *d = Get_Domain(1);
face_t f;
real NV_VEC (A);
real force;
real mass = 1.443;
real wn = 0.183;
real k = mass*wn*wn;
real c = 2*mass*wn*0.0072;
/* reset velocities */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
if (!Data_Valid_P ())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
force = 0.0;
begin_f_loop (f, t)
F_AREA (A, f, t);
force += F_P (f, t) * NV_MAG (A);
end_f_loop (f, t)
/* compute pressure amplitude of motion by Finite Different Method*/
NMAX = int(time/dtime) + 1;
real X[NMAX];
for(int i = 0; i < NMAX; i++){
X[0] = 0;
X[1] = 0;
X[i+1] = (force - X[i-1]*(mass/(dtime*dtime) - c/(2*dtime)) - X[i]*(-2*mass/(dtime*dtime) + k))/(mass/(dtime*dtime) + c/(2*dtime));
X[i+1]=DT_CG(dt)[1]; /*Assign to updated */
Message ("time = %f, force = %f, displacement = %f\n", time, force, X[i+1]);
fout = fopen("results.txt", "a");
fprintf(fout, "%f %f %f\n", time, force, X[i+1]);
fclose(fout);
Thanks for your help
Linh
linh nguyen is offline   Reply With Quote
sdof, udf cg motion
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
