dynamic meshing UDF motion coding issue!
Hello!
I am trying to simulate a 2D moving piston to analyse the pressure flow field in a closed system. I currently have a rectangular mesh and am trying to write a Define_GEOM macro to define the motion of one moving boundary to simulate the movement piston. I do not have much experience with coding, but have been looking at various tutorials and examples and have so far come up with the following code: #include "udf.h" DEFINE_GEOM(moving_boundary,domain,dt,position) int position; for (int position=0; position<=230.5; position++) { nextposition = position+1; if (position<230.5) { nextposition = - 138399*position*position + 2716.6*position - 0.7678; } position = nextposition; } The code contains a simple sin function: y = -138399x^2 + 2716.6x - 0.7678 which should allow the piston to accelerate and decelerate. The code is designed to move the piston wall from position 0mm to position 230.5mm and then stop. So I want the position to increment at 1mm every iteration from 0mm to 230.5mm at a rate of the sin function shown. I am getting a lot of errors with this though and was hoping someone might be able to help!:confused: Originally I used this code: { position[1] = - 138399*position[0]*position[0] + 2716.6*position[0] - 0.7678; } and managed to hook it to my model, however as there is no loop function, the wall only moves slightly once. Any help would be massively appreciated. Thanks! Lisa |
