Fluid force in UDF
Old   May 21, 2014, 08:02
Default Fluid force in UDF
Linh Tuan The Nguyen
linh nguyen is on a distinguished road
Hi, I am doing the external flow around the cylinder free oscillating in y-direction, a system the cylinder in fluid flow attached with spring and damper.
I had used SDOF function in Fluent and obtained some results.
But in the function for prop[SDOF_LOAD_F_Y], i just included elastic force, I also want to integrate fluid force into the equation. Anybody know how to include fluid force into UDF.
Thanks
DEFINE_SDOF_PROPERTIES(stage, prop,dt, time, dtime)
Thread *t;
Domain *d = Get_Domain(1);
real cg;
real vel;
real mass = 1.443;
real wn = 0.183;
real z = 0.0072;
real k = mass*wn*wn;
real c = 2*mass*wn*z;
int j;
prop[SDOF_MASS] = 1.443;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Z] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_ZERO_ROT_Z] = TRUE;
cg = DT_CG(dt)[1];
vel = DT_VEL_CG(dt)[1];
prop[SDOF_LOAD_F_Y] = - k*cg - vel*c; /*function to update force into fluent*/
linh nguyen is offline   Reply With Quote
udf and programming
[URGENT] Drag Force UDF in Power-Law Fluid ali hemmati Fluent UDF and Scheme Programming 2 June 13, 2017 03:37
UDF for defining a body force in Singel ROtating Reference Frame teymourj Fluent UDF and Scheme Programming 9 August 18, 2016 15:33
UDF for force and equilibrium position elcino Fluent UDF and Scheme Programming 6 March 17, 2013 03:38
Help: UDF of "particle body force" !!! zhaoh FLUENT 3 January 16, 2007 20:17
