UDF for Mass Flow at the Outlet: ERROR ACCESS VIOLATION
Like Tree1Likes
  • 1 Post By I-mech
Old   May 23, 2014, 11:45
Red face UDF for Mass Flow at the Outlet: ERROR ACCESS VIOLATION
Marco Dc
I-mech is on a distinguished road
I would really appreciate if somebody take a look in the UDF and give me some advices.
I'm trying to define the temperature at the Pressure Inlet (ID=9) from the temperature at Pressure Outlet (ID=10).
So i've written an UDF that in order:
1. defines temperature dependent viscosity;
2. calculates massflow at outlet;
3. calculates massflow at inlet;
4. calculates averaged temperature at outlet;
5. defines the temperature for the pressure inlet.
At the beginning of the solution the following error occurs:
iter continuity x-velocity y-velocity z-velocity energy time/iter
Error:
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\3d\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
Viscosity UDF works for sure so i've tried to run the simulation only with the following UDF:
Define scalars for following operations
real flowout_tot;
real flowin_tot;
real tavg_tot;
UDF measuring mass flow at pressure outlet ID 10
DEFINE_EXECUTE_AT_END(measure_flow_out)
Domain *d;
real flowout;
cell_t c;
Thread *tout;
face_t f;
d = Get_Domain(1);
tout = Lookup_Thread(d,10);
begin_f_loop(f,tout)
flowout+=F_FLUX(f,tout);
end_f_loop(f,tout)
printf("MASS Flow Rate Out: %g\n",flowout);
flowout_tot = flowout;
flowout = 0.;
I have seen in other threads something very similar so i really don't understand where is the problem.
Thanks in advice
Marco
I-mech is offline   Reply With Quote
Old   May 23, 2014, 12:37
Marco Dc
Looking the UDF row by row i've found there was a Get_Domain_(11) instead of Get_Domain(1).
Now the UDF is working.
I've attached the complete UDF for those who are looking for something similar, and for those who have useful advice to give me.
UDF for Temperature dependent Dynamic Viscosity
#include "udf.h"
#include "math.h"
DEFINE_PROPERTY(cell_viscosity,cell,thread)
real mu_lam;
real temp = C_T(cell,thread);
mu_lam=0.0000631*pow(10,3.722*pow(1+(temp-273)/(135),-1.102));
return mu_lam;
real flowout_tot;
real flowin_tot;
real tavg_tot;
Domain *d;
real flowout;
cell_t c;
Thread *tout;
face_t f;
d = Get_Domain(1);
end_f_loop(f,tout)
flowout = 0.;
UDF measuring mass flow at pressure inlet ID 9
DEFINE_EXECUTE_AT_END(measure_flow_in)
Domain *d;
real flowin;
cell_t c;
Thread *tin;
face_t f;
d = Get_Domain(1);
tin = Lookup_Thread(d,9);
begin_f_loop(f,tin)
flowin+=F_FLUX(f,tin);
end_f_loop(f,tin)
printf("MASS Flow Rate In: %g\n",flowin);
flowin_tot = flowin;
flowin = 0.;
UDF measuring Temperature at pressure outlet ID 10
DEFINE_EXECUTE_AT_END(Temp_outlet)
Domain *d;
real Temp_t;
real area;
real area_tot;
real tavg;
real A[ND_ND];
Thread *t;
face_t f;
d=Get_Domain(1);
t=Lookup_Thread(d,10);
tavg=0;
area_tot=0;
begin_f_loop(f,t)
F_AREA(A,f,t);
area_tot += NV_MAG(A);
tavg += F_T(f,t)*NV_MAG(A);
end_f_loop(f,t)
tavg /= area_tot;
tavg_tot=tavg;
printf("Averaged Temperature at Pressure Outlet: %g\n",tavg_tot);
UDF settting temperature at pressure inlet ID 9
DEFINE_PROFILE(temp_mixing,t,i)
real lambda=1;
real temp_mix;
real temp_supply=323;
face_t f;
if (ABS(flowin_tot) == 0)
temp_mix = temp_supply;
else
temp_mix = (lambda*ABS(flowout_tot)*(tavg_tot)+(ABS(flowin_to t)-lambda*ABS(flowout_tot))*temp_supply)/(ABS(flowin_tot));
begin_f_loop(f,t)
F_PROFILE(f,t,i) = temp_mix;
end_f_loop(f,t)
printf("Adjusted temperature: %f\n",temp_mix);
macfly likes this.
Marco
UDF to adjust pressure outlet a.lynchy FLUENT 4 February 15, 2021 00:50
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 09:38
Outlet BC for subsonic flow in pipe andrea panizza FLUENT 6 May 10, 2003 07:44
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
