May 29, 2015, 05:49 |
Activate Stoke-cunningham drag force in DPM
YANNAPOL SRIPHUTKIAT
Rep Power: 11 |
Dear All,
I would like to activate Brownian Motion Panel in order use Stoke-cunningham drag force. I attach my screen shot for you to see (attachment: ScreenShot) This is the manual from Fluent, this one has Brownian Motion http://www.arc.vt.edu/ansys_help/flu..._optional.html |
May 29, 2015, 06:18 |
Rep Power: 18 |
Ensure you are solving the energy equation because Brownian motion is a function of temperature; consequently, Fluent requires the energy equation enabled for Brownian motion.
Brownian motion is enabled on individual injections from ANSYS Fluent 15.0 (possibly one or two versions prior as well), instead of from the DPM > Physical Models tab which you have attached. What context are you modelling, are you looking at colloidal particles in particle-laden gas flows? You may need to determine the Cunningham correction factor. |
May 29, 2015, 06:30 |
Rep Power: 11 |
Dear "e"
Thank you for your reply, in this case it is a particle in gas flow. I already activate the energy equation, but it does not have Brownian motion tab in DPM. Please advise Best Regards, Yannapol S. |
May 29, 2015, 06:35 |
Rep Power: 18 |
May 29, 2015, 06:41 |
Rep Power: 11 |
DEAR "e"
Ohhhhh Thank you ...... finally i find that Haha = =" Best Regards, Yannapol S. |
December 13, 2016, 02:39 |
hi
EMAVI V SURYA SAMPATH
Rep Power: 14 |
:-) got it
dpm, dpm fluent model, fluent 14.5 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Force vectors for drag during sweeping motion | aamer | FLUENT | 0 | April 18, 2011 08:17 |
formula used for drag force? | kamma | Main CFD Forum | 0 | April 2, 2010 10:21 |
DPM drag force UDF | hedonists | FLUENT | 0 | March 12, 2003 21:10 |
