Loop of a inlet mass flow rate
Old   August 22, 2014, 05:11
Default Loop of a inlet mass flow rate
Thomas Green
.Thomas. is on a distinguished road
Hi all,
I have a problem with my UDF. I am trying to create a cycle of a well defined mass flow rate in the inlet of a square channel. I need to create a loop for a inlet mass flow rate of 1.5 if the time is under 10 seconds and when it is over 10 seconds it should be 8.33 until it arrives to 20 seconds. These two steps (high & low mass flow rate) then should be cycled 200 times.
Below I attach the code I wrote to clarify the problem.
#include "udf.h"
int j=0;
int k=10;
int n;
int o;
int m;
int v=10;
DEFINE_PROFILE(flow_profile,t,i){
face_t f;
real ti=CURRENT_TIME;
begin_f_loop(f,t){
for ( n=0; n<=200; n++ ){
if(ti>=j && ti<=v){
F_PROFILE(f,t,i)=1.5;
}else{
o=j+10;
v=k+10;
if( ti>o && ti<=v ){
F_PROFILE(f,t,i)=8.33;
}else{
j=j+10;
v=v+10;
m=n;}
end_f_loop(f,t)
.Thomas. is offline   Reply With Quote
Old   August 22, 2014, 06:24
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
You can use for this FSI one way method
Martin_Sz is offline   Reply With Quote
Old   August 22, 2014, 08:44
Thomas Green
Ok thank you for your fast answer, finally I found the solution only changing some variables.
loop over define_profile, mass flow rate inlet, udf code
Match mass flow rate with inlet pressure and outlet pressure vut Main CFD Forum 9 February 21, 2014 18:07
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 07:55
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
