How to get thread pointer to dynamic volume (not face) in 3D? Problem w DT_THREAD.
Old   September 1, 2014, 12:02
Default How to get thread pointer to dynamic volume (not face) in 3D? Problem w DT_THREAD.
Igor
DaddySpeleo is on a distinguished road
Hi!
I tried to use dynamic mesh, so I use
Thread *t = DT_THREAD(dt);
to get thread pointer to dynamic surface, and it works in 2D without problems.
In 3D case I want to move nodes of volume, but if I use thread pointer from DT_THREAD(dt) I get errors.
If I use t=Lookup_Thread(domain,ID) - OK
But! ID - is a Cell ID! Not ID from boundary conditions which DT_THREAD(dt) returns.
So - I can't transfer thread pointer from my moving volume to UDF, I can only "hardcode" this number (Cell ID) in text of UDF.
How should I use pointers to move volume in 3D?
Best regards,
Daddy
DaddySpeleo is offline   Reply With Quote
dt_thread, dynamic mesh, thread pointer, volume
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
