October 15, 2014, 10:54 |
reverse flow at the outlet
Khalid Ansari
Rep Power: 12 |
hello,
i m working on flow past a rotationally oscillating cylinder. and i m using udf and dynamic mesh for it. so when i m using udf file and running the calculation. it is constantly giving me reverse flow at the outlet. and the solution doesnt converge. pls help me experts. plsss. i extended the outlet far from the cylinder. used 2nd order upwind momentum equation. |
October 18, 2014, 00:53 |
Which boundary condition did you use. My guess is you have used Pressure outlet BC (given your problem is at low RE, if its a compressible flow problem, then its a different game altogether). Try using outflow instead.
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Temperature at a velocity/mass flow outlet | saisanthoshm88 | CFX | 1 | July 8, 2014 18:35 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! | XIAOYI LI | FLUENT | 11 | September 14, 2012 16:43 |
CFDesign V11 -- Reverse flow at outlet | maruthiv | Autodesk Simulation CFD | 1 | June 17, 2011 09:38 |
