August 17, 2014, 18:46 |
volumetric energy source problem
kourosh
Rep Power: 12 |
Hi guys
i am trying to simulate a constant volumetric energy source in a specific zone in my domain in fluent so all the cells within that zone would have same source energy . i wrote the below udf but the problem is temperature wouldn't increase within the zone ....i have already applied the udf to the specific zone....any idea? thanks #include "udf.h" DEFINE_SOURCE(energy_source,c,t,dS,eqn) { real x[ND_ND]; real source; C_CENTROID(x,c,t); source = 50000000000 ; return source; } |
August 18, 2014, 10:55 |
kourosh
Rep Power: 12 |
Hey Guys
I changed the udf as below but still there is no change in the temperature inside my zone, any ideas? Thanks. #include "udf.h" DEFINE_SOURCE(energy_source,cell,thread,dS,eqn) { real source; source = 500000000.; return source; } |
August 18, 2014, 14:41 |
kourosh
Rep Power: 12 |
any suggestions guys? thanks
October 25, 2014, 23:40 |
kourosh
Rep Power: 12 |
any help guys?
October 31, 2014, 17:33 |
François Grégoire
Rep Power: 17 |
Did you try with the dS[eqn] line?
DEFINE_SOURCE(energy_source,cell,thread,dS,eqn) { real source; source = 500000000.; dS[eqn] = 0.; return source; } |
October 31, 2014, 18:47 |
kourosh
Rep Power: 12 |
no it doesn't work i tried it before. i am confused , when i go to my zone in fluent and define the same value as constant parameter it works fine but when i use the above udf nothing happens. i need to do this with udf since i need to make it change with time in the next step.
October 31, 2014, 18:53 |
François Grégoire
Rep Power: 17 |
Have you tried with both interpreted and compiled udf?
October 31, 2014, 19:25 |
kourosh
Rep Power: 12 |
I always interpret(not compiling) my udfs and they worked fine before .when I tried to compile this one it gave an error but I am not sure if this is the source of my problem since it interprets the udf without an error and I can choose it in my zone in fluent.
Thanks for your response . |
November 5, 2014, 03:24 |
#9 |
Jim Knopf
Rep Power: 15 |
And you did specify the source term in the cell zone?
November 6, 2014, 06:34 |
#10 |
Vaze
Rep Power: 16 |
Your cell c and thread t should specifically refers to the zone on which you want to apply source.
You can trace the thread using lookup_thread macro. Best wishes Mvee |
November 6, 2014, 06:37 |
#11 |
Vaze
Rep Power: 16 |
Again, if your source is constant value then you need not to define it through UDF. You can implement it through cell zone conditions.
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
energy source problem | fluboy | Fluent UDF and Scheme Programming | 2 | January 10, 2010 08:56 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
