Setting up a parametric simulation with UDF variables
Old   November 13, 2014, 10:09
Default Setting up a parametric simulation with UDF variables
Rohini Bala Chandran
rohinibc is on a distinguished road
I would like to know how I can set up an input file to run fluent in batch mode to perform a series of simulations. To be more specific, about my problem, here is what I have. In my UDF function, I have 2 parameters, say, a and b and they each can have upto 10 values. I would like to study the influence of these parameters, which would be 100 simulations in total, on a specifically chosen output parameter. While I am able to declare scheme variables and invoke them within my UDF file, I don't know how to set up an input file to loop over the various values for the parameters.
Or, is there another way that I can interface Fluent with some other scripting language such as Fortran /Python/Matlab and run within scripts that are setup in these languages? Any help with this would be greatly appreciated.
rohinibc is offline   Reply With Quote
Old   November 13, 2014, 19:59
François Grégoire
macfly is on a distinguished road
I would go with a journal file that executes the following commands a 100 times:
- read case
- interprete or compile UDF
- solve and save
BUT, I would generate the journal file and the 100 different UDFs with Python, Matlab, etc.
macfly is offline   Reply With Quote
Old   November 14, 2014, 10:24
Andrew Kokemoor
Kokemoor is on a distinguished road
Macfly's approach is probably the best, though if you've already set your UDF up to read scheme variables, you can just change the scheme variables 100 times and always use the same UDF.
Kokemoor is offline   Reply With Quote
Old   November 18, 2014, 18:13
Thanks all. I did what Macfly suggested. Generated a script to produce my input file for Fluent to run in batch mode.
However, I also recently saw that in version 15.0, there is the possibility of declaring input parameters that can be read into UDF files. This I think directly syncs up with the RSM options in WorkBench too. I am yet to execute this to see how it works out.
Old   November 19, 2014, 10:52
Andrew Kokemoor
DEFINE_OUTPUT_PARAMETER (2.2.10 in the UDF Manual) is a pretty straightforward macro to calculate an output parameter in the UDF. RP_Get_Input_Parameter("variable name") is the function to read input parameters, though I haven't used it myself. Section 3.6.4 of the UDF Manual has other functions to read from scheme variables as well.
batch simulations, parametric study, udf variables
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
Dynamic simulation for unknown variables? fatb0y CFX 4 December 8, 2010 19:26
execute udf in ss & transient simulation hosseinhgf FLUENT 0 December 1, 2010 08:41
multiphase UDF, variables for phase velocities Kerem FLUENT 4 March 27, 2006 08:20
