December 24, 2014, 14:12 |
Compile udf
mojtaba
Dear My collegue
I wote a UDF for volumetric reaction but I cannot compile it before using the ANSYS FLUENT 14.5 I would be approciate every body that can help me. The written program (rate.c) are as the following. Please write to me the response and send to "mojtaba.aslani66@gmail.com" #include "udf.h" #define R 8.314 DEFINE_VR_RATE(reaction,c,t,r,mw,species_massf,rat e,rr_t) { real n_CO2=species_massf[0]/mw[0]; real n_CO=species_massf[1]/mw[1]; real n_H2=species_massf[2]/mw[2]; real n_CH4=species_massf[3]/mw[3]; real n_N2=species_massf[4]/mw[4]; real n_H2O=species_massf[5]/mw[5]; real Total_n=(n_CO2+n_CO+n_H2+n_CH4+n_N2+n_H2O); /*mole fraction*/ real mf_CO2=n_CO2/Total_n; real mf_CO=n_CO/Total_n; real mf_H2=n_H2/Total_n; real mf_CH4=n_CH4/Total_n; real mf_H2O=n_H2O/Total_n; /*pressure*/ real P=C_P(c,t); /*Temperature*/ real T=C_T(c,t); /*Partial pressures*/ real P_CO2=mf_CO2*P; real P_CO=mf_CO*P; real P_H2=mf_H2*P; real P_CH4=mf_CH4*P; real P_H2O=mf_H2O*P; /*Kinetic coefficient*/ real k_1=1.17e15*exp(-240100/(R*T)); real k_2=2.83e14*exp(-243900/(R*T)); real k_3=5.43e5*exp(-67130/(R*T)); /*Equilibrium constant*/ real K_CO=8.23e-5*exp(70650/T); real K_H2=6.12e-9*exp(82900/T); real K_H2O=1.77e5*exp(-88680/T); real K_CH4=6.65e-4*exp(38280/T); real Ke_1=exp((26830/T)+30114); real Ke_2=exp((4400/T)+4.036); real Ke_3=Ke_1*Ke_2; /*Needed for calculations*/ real DEN=1+K_CO*P_CO+K_H2*P_H2+K_CH4*P_CH4+K_H2O*P_H2O/P_H2; if (!strcmp(r->name, "reaction-1")) { *rate=2.2275*(k_1/pow(P_H2,2.5))*(P_CH4*P_H2O-pow(P_H2,3.5)*P_CO/Ke_1)/pow(DEN,2); } else if (!strcmp(r->name, "reaction-2")) { *rate=2.2275*(k_2/pow(P_H2,3.5))*(P_CH4*pow(P_H2O,2.5)-pow(P_H2,4)*P_CO2/Ke_3)/pow(DEN,2); } else if (!strcmp(r->name, "reaction-3")) { *rate=2.2275*(k_3/P_H2)*(P_CO*P_H2O-P_H2*P_CO2/Ke_2)/pow(DEN,2); } *rr_t=*rate; } |
December 24, 2014, 16:24 |
hosein
Rep Power: 12 |
hi mojtaba.
Did you try this: step1: uninstall visual studio express 2013 or 2010 or c++ step2: install Microsoft Visual Studio 2010 Ultimate v10.0 (or pro) everything is fine even dont need to start workbench or fluent from SDK |
December 25, 2014, 12:43 |
mohsen
Rep Power: 11 |
hi friends
is u'r problem with compiling the udf or writing udf code?if that is compiling what is the error? |
May 19, 2020, 21:43 |
zaixing
Rep Power: 5 |
Hello,friend.My doctoral project is aslo about Steam Reforming by using CFD.
I also face the same problem. How did you solve it? |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Fluent does not always compile UDF properly | davesmith_01 | Fluent UDF and Scheme Programming | 3 | February 10, 2011 14:09 |
UDF COMPILE | Miguel Olvera | FLUENT | 4 | March 18, 2007 08:07 |
Fluent doesn´t compile UDF on Windows | HSeldon | FLUENT | 4 | February 14, 2007 23:01 |
UDF compile HELP!! | Leigh | FLUENT | 19 | August 27, 2006 23:03 |
